Convert C codes to Matlab Codes
Vila
@vila-4EJWAr โ€ข Oct 25, 2024
Hiiii everybody,
How do i change or convert C codes to Matlab codes? Is there any software that can convert C codes to Matlab codes? I have lots of C codes here, but i need them all in Matlab codes form.
Thank you...
  • Vila
    Vila OP
    @vila-4EJWAr • Nov 7, 2008
    Hiiii everybody,
    Thank you...
  • anuragh27crony
    @anuragh27crony-mb8hAE • Nov 10, 2008
    there's no need to convert the C-Code into Matlab...
    as far as i know, we can run C-code directly in Matlab... I don't know exactly but need to check it once.... :smile:
  • Vila
    Vila OP
    @vila-4EJWAr • Nov 17, 2008
    Hiiiii,
    Yes its done by using the MEX file. But i dont know how to use the MEX file inside C codes to make it run in Matlab. Besides the header file, where else do we need to include the MEX file, and when to include it? and also how to use the MEX file?
    Thankss...
  • akshu
    @akshu-k29zrK • Jan 30, 2009
    hi, all
    anybody help me out regarding Convert C codes to Matlab Codes.
    Thanks..
  • durga ch
    @durga-TpX3gO • Jan 31, 2009
    I had this thought that MATLAB follows the syntax of C codes.
    I found this out from mathworks.com
    Lokks like all you need is a matlab C complier and then changing the main() function in your C code to mexfunction and remainging all should work as the syntax is same
    look for more! ๐Ÿ˜€
