conversion of 32 bit memory into 16 bit memory
sushant005
@sushant005-tyt4WK โ€ข Oct 27, 2024
Can any one solve my conflict.
Is it possible to convert 32 Bit memory into 16 Bit memory.
If yes then how?
Give me some ideas.
correct me if i am wrong
๐Ÿ˜
  • shruti palod
    @shruti-palod-Sarni8 • Feb 14, 2010
    Hi
    can you plz elaborate Your Question.
    And why do you want to convert 32 bit memory to 16 bit?
  • sushant005
    @sushant005-tyt4WK • Feb 14, 2010
    shruti palodHi
    I just want to know that, whether an application software which is compatible with 32 Bit operating system can be same with 16 Bit operating system It means that can we install the same to the 16 Bit operating system.
    if it does not support 16 bit operating system ,then is it possible to convert 32 Bit memory to 16 Bit memory so that it run on that.
    that why i want to know the conversion is possible.
    ๐Ÿ˜’
  • shruti palod
    @shruti-palod-Sarni8 • Feb 20, 2010
    Hi
    A 32 bit application is compatible with a 16 bit OS but reverse is no true.๐Ÿ˜
