Control any device using SMS.
Before I begin with the project description I consider it pretty important that you get to know how de communication with the mobile phone is done. For this you should check out the following links first.
The first link is a link to the wikipedia site that helps you udnerstand the basics of the AT (Hayes) Command Set:
https://en.wikipedia.org/wiki/Hayes_command_set
The following link is a .pdf file that lists the AT commands that you need to send to the mobile phone through the serial interface. The AT commands are basically the same for most GSM modules/phones with slight variations.
https://ebookbrowse.com/s35i-c35i-m35i-atc-commandset-v01-pdf-d29637636
Finally I added this link that explains in detail how to send and receive SMS messages with the help of AT commands and how exactly those messages are encoded (PDU format):
https://www.dreamfabric.com/sms/
<a href="https://yanivx.wordpress.com/2011/02/05/my-first-project-control-anything-using-sms/block_diagram/" target="_blank" rel="nofollow noopener noreferrer">Controlling devices using SMS | Gyani</a>
2. Description of the individual blocks
As mentioned above I have chosen the ATmega16A microcontroller. The program I have written takes up less then 8kB so an ATmega8A would be just as good. You can look for microcontrollers from other manufacturers as well. All this project needs is a standard IO port with 8 pins and an asynchronous serial interface (RX and TX pins). Also for ease of programming ISP capability would be good.
The ISP interface is a simple 6 pin (3Ã2) header connected to the corresponding pins of the microcontroller. I have designed mine to work with the AVRISP mkII that connects to the USB port of the PC. There are many different possibilities to make your own in-system-programmer but most of them are either designed for a parallel or serial port or require a programmed microcontroller. Also the AVRISP mkII is very easy to use with AVR Studio and not too expensive.
Since I use the data cable of the Siemens M55 to communicate with it and didnât want to destroy it I had to translate my TTL level serial communication from the microcontroller to RS-232 levels. If you have a GSM module that works with TTL levels (or connect directly to the corresponding pins of the phone, that also operate at TTL levels) you donât need a level converter and can connect the module directly to the RX and TX pins of the microcontroller. If you use a data-cable that operates at RS-232 levels (designed to communicate with PC) then you need a MAX232 or similar IC. The MAX232 is very easily implemented. It only needs some capacitors and you can connect the RX and TX pins of the TTL levels on one side and get RS-232 levels on the other. The following image should give you a better idea of what I am talking about if you didnât use this IC before. The picture is from the MAX232 datasheet
<a href="https://yanivx.wordpress.com/2011/02/05/my-first-project-control-anything-using-sms/max232/" target="_blank" rel="nofollow noopener noreferrer">MAX232 | Gyani</a>
The capacitors are of 1uF each.
I will describe the relay driving circuit for 1 relay. It is the same for the other 3 relays. The relays that I have used are latching type relays with 2 coils. Both coils can be sued to set or reset the relay. To keep the command simple I have used one IO pin to set and one IO pin to reset the relay, commanding the two coils individually. To be able to supply the necessary current for the relay to latch, I have used npn transistors with a current limiting resistor in the base of the transistor, that is connected to the microcontroller IO pin. Since I use 2 IO pins to command each relay and those lines are always at different logic values (either the set or the reset line are at +5V) I have mounted a bicolor led and a current limiting resistor between the two IO lines to visualize the position of the relays. For a better understanding of the relay driving circuit look at the schematic further down.
The power supply consists of a 7805 voltage regulator. It can be supplied by any DC voltage between 7 and 35V (35V is the absolute maximum rating. I wouldnât go that high
). Along with the 7805 I have added some filtering capacitors at the input and output of the IC.
3. Electrical schematic
I have designed this project in EAGLE. Since the dimensions are not that big the light (free) version of EAGLE was all I needed.
Also worth mentioning is that I have connected one of the pins of the ADC to a 3 pin header along with VCC and GND to be able to add a temperature sensor to the project in case I decide to modify the project. If you donât want this you can also leave the AREF and AVCC pins unconnected.
<a href="https://yanivx.wordpress.com/2011/02/05/my-first-project-control-anything-using-sms/schematic/" target="_blank" rel="nofollow noopener noreferrer">circuit diagram | Gyani</a>
4. Board layout
<a href="https://yanivx.wordpress.com/2011/02/05/my-first-project-control-anything-using-sms/layout/" target="_blank" rel="nofollow noopener noreferrer">PCB layout | Gyani</a>
I will only post the complete layout with both Top and Bottom sides. The EAGLE file is linked below.
The drill sizes are rounded to mmâs. So if youâre living in the stone age and donât use the metric system
you will probably have to modify them.
I have uploaded the schematic and the board layout to a free file hosting server but I donât know how long it will stay up. If you want it and the link isnât working just send me a mail. The folder also contains the component library. Link: <a href="https://www.mediafire.com/?h6taq8dk9g2xq" target="_blank" rel="nofollow noopener noreferrer">My Files</a>
4. Software
The software was written in AVR Studio with the WinAVR plugin installed. I have written it in c programming language since assembly is just a pain in the a**.
Basically what the microcontroller is doing is initializing the serial interface and then the phone. Initialization of the phone means inserting the pin number (I have put it to 1234 in the program), selecting the storage for SMS messages (it selects the phone memory and not the SIM memory) and inserting the SMS service centre address. The current address is for a Vodafone Romania prepaid SIM. These parameters are at the beginning of the program so you shouldnât have a hard time changing them even if you have no clue of C programming. Below is the block diagram of the software. It is written in romanian but basically the idea is:
- you initialize the serial port, the phone and set the IO pins to output;
- you keep asking the phone if it has any unread messages (with the AT command âat+cmgl=0â³)
- if so you check whether the message starts with a âRâ or a ârâ. This is because the message to change the relay positions has to be âR xxxxâ where x is either 1 or 0 according to what position the relay has to have. Also this allows us to ignore messages from other people.
- if the message starts accordingly you modify the relay positions so that they correspond to the SMS.
The code for the programming is uploaded on mediafire here is the link >><a href="https://www.mediafire.com/?p6ed2aevw7c447h" target="_blank" rel="nofollow noopener noreferrer">SMScontrolledRelay_final</a> just download it and burn it on the microcontroller using AVR studio 4 njoyâ¦.. ![]()
Regards Yanivx
<a href="https://yanivx.wordpress.com/" target="_blank" rel="nofollow noopener noreferrer">Gyani | Do not go where the path may lead; go instead where there is no path and leave a trail.</a>
Congrats to me I did it i am done with " Controlling Industrial Hazards Using GSM " I will upload every minutes of this project very soon thanks for the encouragement.
