CrazyEngineers Archive
Old, but evergreen and popular discussions on CrazyEngineers, presented to you in read-only mode.
@jaspal rautela • 04 Jul, 2012
what is consumable and non-consumable electrode?? and where it is used??
@venkatking.v • 05 Jul, 2012
Both are used in Welding.. Electrode which is used also filler material in welding process is called as consumable electrode, here we should feed the electrode continuously example MIG. then which is used only electrode is called as non- consumable electrode example TIG.
@jaspal rautela • 05 Jul, 2012
what is the functin of shield gas and flux in welding process?
Flux used to prevent the oxidation of molten materials [work piece & filler rod] .jaspal rautelawhat is the functin of shield gas and flux in welding process?
@mechky • 08 Jul, 2012
Electrodes that do not melt under the heat of welding are non-consumable electrodes. They just act as a positive or negative electrode to form electric arc. Carbon & tungsten electrodes are non-consumable.
When electrode itself gets melted and becomes a part of weld puddle, the electrode is known as consumable electrode. Consumable electrodes perform both the functions as they act as electrode to form arc and provide filler metal as well as flux.jaspal rautelawhat is consumable and non-consumable electrode?? and where it is used??
@mechky • 08 Jul, 2012 • 2 likes
- Provides inert atmosphere and protects molten and heated metal from the surrounding air. If air comes in contact with the molten or heated metal, the oxygen in the air will oxidize the metal, the nitrogen might cause porosity or brittleness in the weld metal and moisture from the air might also cause porosity.
- Shielding gas composition affects metal transfer from the electrode to the weld pool, which in turn influences the amount and size of the spatter created. It also affects the appearance of the weld bead, the weld geometry & the possible welding speed.
Functions of flux coating in electrodes:
- Flux combines with impurities in molten metal to form slag which is lighter and solidifies on top and can be scrapped off easily
- Flux prevents rapid solidification of weld metal
- Directs the arc to the welding zone
- Flux is usually bad conductor of electricity so it allows electrodes to be used in narrow regions without danger of electric short-circuit
Functions of shielding gases:jaspal rautelawhat is the functin of shield gas and flux in welding process?
@Ramani Aswath • 08 Jul, 2012
Another main function of flux is to reduce the melting point of the electrode to enable it to penetrate the intersection better. It also helps wetting.venkatking.vFlux used to prevent the oxidation of molten materials [work piece & filler rod] .
@abdala bakheet • 13 Feb, 2015
what is the consumable electrode aw processes
@TINKAJ Rana • 13 Apr, 2015
if an electrode produce electric arc and also act as filler metal is known as consumable electrode.for example-MIG.
and if an electrode only provides positive and negative charge to form electric arc is called non-consumable electrode.for example-carbon,tungsten etc.
28.8k views
@imgopi · Aug 25, 2013
Hi friends am a student of University of Adelaide, Australia. I need one innovative non technical seminar topic like Solar powered Catamaran, Automatic Car parking System.
Please give me your...
21.9k views
@whiz.kid.aniket · Feb 27, 2010
Make your very own Pendrive a Portable RAM (virtual)😁
Just Follow these steps :-
1. Insert the Pen Drive (1GB atleast) in the USB port, i suggest you use 4GB....
5.6k views
@Sarathkumar Chandrasekaran · Sep 10, 2013
I had seen many movies in which heroes used to put sugar/sand inside the petrol tank to seize the engine But is it true that the engine got seize or...
3.5k views
@maria james · Sep 28, 2012
Final year b.tech student in search of a new,relevant,attractive theme for college magazine.eg:energy conservation,green energy..
5.7k views
@safwan · Aug 31, 2009
I am learning visual studio 2008 . I want to join my project with sql server 2008(Specifically not any other like oracle or mysql ) . Firstly I want to...
7.1k views
