@jeffrey-xA7lUP • Sep 17, 2013
Do feel this will work out for you?
I found this as a way of connecting the Rpi and arduino I am looking for other possible I will post as I find them here -
@abhishek-fg9tRh • Sep 17, 2013
This is way too much of mindfuck, man.
I wanna keep it simple for that. I can connect RPi with Uno over Serial GPIO using Logic Level Converter, but now I simply wanna know that, is there any other way of connecting Pi with Uno w/o using LLC.
I will be damned if I use that instructables method just for connecting Pi with Uno (because simplest way is available) :
Okay there are few configurations to be done. But it's still simple than the one mentioned in instructables.
Back to query, Any other method of connecting Pi with Uno w/o using LLC ? -
@durga-TpX3gO • Sep 17, 2013
the volt variation does need a LLC. nevertheless, there seems to a hack available (involves, replacing the regulator ) if you want to take the plunge here :
<a href="https://learn.adafruit.com/arduino-tips-tricks-and-techniques/3-3v-conversion" target="_blank" rel="nofollow noopener noreferrer">3.3V Conversion | Arduino Tips, Tricks, and Techniques | Adafruit Learning System</a> -
@harshad-ukH5ww • Sep 19, 2013
If you are using Pin in one direction only then I think voltage divider is the best option.
@abhishek-fg9tRh • Sep 19, 2013
Harshad ItaliyaIf you are using Pin in one direction only then I think voltage divider is the best option.
Explain me with circuit diagram ?
