Computer networks
anandkumarjha
anandkumarjha
@anandkumarjha-jzdDMA Oct 21, 2024
Hello CEans
what is meant by IP address of switch,and port number and how does it works??please explain
  • shreyasm89
    shreyasm89
    @shreyasm89-jGobVm Sep 18, 2010
    What is a wwitch?Did you mean witch?
  • anandkumarjha
    anandkumarjha
    @anandkumarjha-jzdDMA Sep 18, 2010
    sorry brother....it's switch.....i wrongly written it as wwitch...but now currected after editing
  • shreyasm89
    shreyasm89
    @shreyasm89-jGobVm Sep 19, 2010
    An IP address is a 32-bit number allocated to a network location.There are 4 classes of IP addresses-Class A,Class B,Class C, Class D.Actually we have even Class E but that is for future expansion & is not currently used on IP networks. Any IP address is divided into two parts-Network ID & Host ID. The network ID decides the level of sub-networks you can have according to a particular class.More the no. of bits in a network ID more is the no. of computers you can have on a higher level. For branching out multiple connections from a host we need a switch.But since the data packets have an IP header in which the IP address of the destination host is stored it has to be routed to the proper switch.Since this switch is occupying a node in the network it has to be assigned an IP address.
  • jessiehilty
    jessiehilty
    @jessiehilty-xTsUAH Sep 20, 2010
    A computer network often simply referred to as a network, is a group of computer and devices interconnected by communications channels that facilitate communications among users and allows users to share resources. Networks may be classified according to a wide variety of characteristics. Thanks for sharing...
    ______________
    <clipped by spam-eater>
  • durga ch
    durga ch
    @durga-TpX3gO Sep 21, 2010
    switch is a layer 2 network device.
    A port on a switch is where you can connect your device [​IMG]
    what do you want to know exactly?
  • anandkumarjha
    anandkumarjha
    @anandkumarjha-jzdDMA Sep 22, 2010
    durga
    I exactly wanted to know the uses of switches and port number in networking...
  • durga ch
    durga ch
    @durga-TpX3gO Sep 22, 2010
    are you familiar with hubs? Hubs sebd the data onto all the ports except on the port it recieves, but switches are a little more intelligent. When I say Layer 2 network elements, it can be deduced that we are talking about mac IDS of computer. So consider your LAN, and you ahve a switch with 4 ports , you recieve a packet destined to a computer on port 4, switch looks up its internal tables to deduce where the mac address of the computer 4 is located , and forwards it according.We dont call it routing as routing is generally done at L3.
    Ports are where the devices connected to, another advantage of using ports is creation of virtual LANs
