Compatibility issues with Oracle 10g and JDk1.6?
patil.ashu01
@patilashu01-wqV4iY โ€ข Oct 21, 2024
Hi. I am trying to make a database connection in Eclipse with Class.forName("oracle.jdbc.driver.OracleDriver") or DriverManager.registerDriver(new oracle.jdbc.driver.OracleDriver()). I have also added an external jar file classes12.jar but I am getting an exception :
java.lang.ClassNotFoundException: oracle.jdbc.Driver.OracleDriver
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1680)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at LoginDAO.<init>(LoginDAO.java:9)
at Hello.doGet(Hello.java:30)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) .....
even if there is no compilation error. I am using Oracle 10g and JDK1.6 . Is there any need to include other jar files or configure anything else??? Please help.
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Apr 24, 2013
    It's clearly a classpath issue. Where have you added classes12.jar?
  • patil.ashu01
    @patilashu01-wqV4iY • Apr 24, 2013
    Anand TamariyaIt's clearly a classpath issue. Where have you added classes12.jar?
    in eclipse through Configure build path-> add external jar files->select classes12.jar. this is displayed under libraries. I tried it this way that removed a compilation error in Class.forName() but gives an exception.
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Apr 25, 2013
    Put it in WEB-INF/lib folder.
  • patil.ashu01
    @patilashu01-wqV4iY • Apr 26, 2013
    I copied the file in WEB-INF/lib. bt getting the same exception
  • patil.ashu01
    patil.ashu01I copied the file in WEB-INF/lib. bt getting the same exception
    I am using a tomcat server.. so is the problem arising due to oracle 10g,jdk1.6 and tomcat v6.0???? Please help.. I am stuck here..
  • patil.ashu01
    finally its done.... THANK YOU... As #-Link-Snipped-#, you said I had to set a classpath environmental variable. but I couldnt do it from cmd prompt but from my computer->manage->environmental variable. But both the methods do the same. rite??? then y cant i do it through cmd prompt???? And also classes12.jar file has to be included under WEB-INF/lib , otherwise an exception is raised. but this works with jboss by simply including jar files using Build path->configure build path->libraries->add external jars.
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Apr 27, 2013
    Variables set in a cmd prompt is only available in that session, one set via computer->manage->environmental variable is available to all new processes. Some server plugins in eclipse use the project classpath setting. Hence, you don't see the issue with JBoss. But it's not a fool-proof mechanism. For a web app, the proper way to provide for Jars is to put them under WEB-INF/lib.
