Comparison of Results in Welding Project
N.Gowtham Raj
N.Gowtham Raj
@ngowtham-raj-PZyKS4 Oct 10, 2024
Hey guys, am doing a project in welding... Two set of welds .... After testing, i will get any one of the set with superior quality, but how do i validate the results? Is there any standard procedure for that???
  • CE Designer
    CE Designer
    @ce-designer-BWq0yl Jan 23, 2012
    Use MPI testing or x-raying, pressure testing? Not sure what you need, maybe you can elaborate a little more.
  • N.Gowtham Raj
    N.Gowtham Raj
    @ngowtham-raj-PZyKS4 Jan 24, 2012
    Am using Tensile test, Impact Test, Hardness Test, and Optical micrograph....Any suggestions now?
  • CE Designer
    CE Designer
    @ce-designer-BWq0yl Jan 24, 2012
    What is the aim of this experiment????????
    Do you want to compare 2 different types of welds?
    Stop posting random questions off the top of your head, if you want an intelligent answer present your question too intelligently and CLEARLY!👀
  • zaveri
    zaveri
    @zaveri-5TD6Sk Jul 16, 2012
    maybe he wants to compare the strengths of two different welds, by performing various tests. I think some of the guys in my class did a similar project in the metallurgy lab.
