  • Code to resolve captcha and resolve barcode data from 2 different images using php
    Nayan Goenka
    Nayan Goenka
    @nayan-Dhpt4N
    Updated: Oct 24, 2024
    Views: 1.0K
    Hey i m writing a code to resolve captcha and resolve barcode data from 2 different images using php. the images that needs to be resolved is in the same directory as the code. But the code isnt fetching it. Anyone any help on this function? The part of code which fetches the image is below.
    public function setImage($img = "php_captcha")
                    if(!$this->LoadImage($img.".png")) echo "Image has not been found";
    Its appreciated if anyone can help on this function. this one works for my other codes but here i m a bit confused. If you need full code I will post it if asked for.
  • Manish Goyal
    MemberAug 4, 2013
    Can you post definition of $this->LoadImage()?
  • Nayan Goenka
    MemberAug 4, 2013
    its default
  • Manish Goyal
    MemberAug 4, 2013
    Impossible
    There is no such function in php named loadImage
    Assuming it is following OOps, check it's parent class
  • Nayan Goenka
    MemberAug 5, 2013
    ohhh abt that function:
    This is it
    private function LoadImage($img)
                    if (file_exists($img))
                                    $image_info = getimagesize($img);
                                    $image_size = explode("\"", $image_info[3]);
                                    $this->image_width = $image_size[1];
                                    $this->image_height = $image_size[3];
                                    $this->img = imagecreatefrompng($img);
                                    return true;
                    else
                                    return false;
  • Manish Goyal
    MemberAug 5, 2013
    The function seems correct
    This function assumes, image file path as it's argument
    Did you check if the path is correct or not?
  • Nayan Goenka
    MemberAug 5, 2013
    checked everything. Funny thing is, the program is running now, but gives an unusual warning now.
    Notice: Undefined offset: 1 in C:\xampp\htdocs\PHP\prog11.php on line 115
    No Characters have been detected
  • Manish Goyal
    MemberAug 6, 2013
    The problem is with this chunk of code
    GetImageSize returns an array, you can't explode it
    Simply remove this line and make it following
    Please check whether it is 1st or 2nd is width
    Thanks
  • Nayan Goenka
    MemberAug 6, 2013
    goyal420
    Thanks
    Thanks for the try but it didnt work out with your code.
