Clear Apti!!
roooooohi
@roooooohi-ONCifU โ€ข Oct 26, 2024
I have not attended any placement drive which does not have aptitude. Although i strongly feel it should not be so.
I mean there can be times when some people are lucky enough to mark the correct option for a question or not lucky enough to miss it all the time.
its totally on your luck + practice.
And in my view it should be like writing down the correct answer rather than ticking one of the options.
    @abhishek-fg9tRh Feb 6, 2015
    roooooohiI have not attended any placement drive which does not have aptitude. Although i strongly feel it should not be so.
    Yes. So how could we help you ?
  • roooooohi
    @roooooohi-ONCifU Feb 6, 2015
    By supporting me here or else making me understand that i am wrong.
    @thebigk Feb 6, 2015
    roooooohiI mean there can be times when some people are lucky enough to mark the correct option for a question or not lucky enough to miss it all the time.
    I can tell you that in my times, I cracked the aptitude purely on the basis of hours of practice. Just ensured that the 'luck' felt jealous of 'practice'.
  • roooooohi
    Me too.
    but i find it a little unfair.
    roooooohiMe too.
    Nope. You can have argument on whether 'apti' is the right way to conduct entrance test. But cracking an apti is a function of practice.
  • roooooohi
    ok but there are times when you guess the answer and yes i don't doubt that you cleared it by practicing.
  • rahul69
    @rahul69-97fAOs Feb 6, 2015
    roooooohiMe too.
    Unfair, huh, Trust me when I tell u this: it is not luck
    Those people call it luck, but the truth is, back in day they have worked so hard that they are getting the fruits of those labor today, and they have forgotten the hardwork they did, and call it luck now.
    Guessing is not simple as it sounds (unless u are closing eyes and ticking ๐Ÿ˜‰ ), Sometime u are using the knowledge gained by your sub conscious, ( u have a gut feeling that it is correct as ur subconscious remembers it), Sometimes u may eliminate wrong options and then take guess, but that also needs at least some knowledge.
    To summarise
    Luck = shot in dark (mostly miss, rarely hit)
    Practice = success is ensured ๐Ÿ˜€
    So don't feel jealous, feel pity on those who are riding on luck as they don't know when they may fall.
    Be positive, Be Happy ๐Ÿ˜
  • Shashank Moghe
    @shashank-94ap1q Feb 6, 2015
    #-Link-Snipped-# your argument dissipates in thin air when the aptitude test has negative marking. That is the correct way of eliminating the luck factor out. Besides, writing down and answer (I suppose you meant arriving at the answer), needs you to exact out the calculations involved. Many a times, having an answer in the ball-park is all that is required to be known. Arriving at the answer might require you to know all the intermediate formulae which is unfair to those who cannot remember formulae (or cannot rote-learn).
    For some reason (which I don't agree with) IT companies in India have accepted aptitude tests as the first round of elimination. Why? Because it's easier to conduct, takes very less time to conduct and get results and ensures the basic level of smartness in the selected candidates. Everyone knows that you 'CAN' be lucky in aptitude tests but there are higher changes that you will be filtered out in the subsequent rounds of selection process.
    I've been through the process and have been on the both sides so I know how it works. Think of it: You're going to hire 10 candidates and there are 500 applicants. How do you know which ones to call for interview? If they're made to write lengthy answers - it's going to take days to correctly evaluate candidates. Not a very practical solution, right?
    The key to cracking aptitude tests is to be smart. You don't have to 'solve' the questions; but just eliminate the wrong answers and make a very smart guess about the right one. If you can master this technique, you will solve any aptitude test in 50% of the time it normally takes. I've seen this technique being used by those who cracked CAT, GRE, GMAT and aptitude tests. Trust me, the technique can be developed through practice. The good thing is that, it's not as difficult as it looks.
