ClampOX - Piping Leak Box-up / Clamp Design Software
ashfaqanwer
@ashfaqanwer-X0CZPx โ€ข Oct 26, 2024
Dear friends,
Sharing with you is an engineering software which designs a box-up / clamp (both welded & bolted) for leaking pipes.
Here are the salient features:
1. Basic clamp thickness calculations based on ASME VIII pressure design formula
2. Calculation of weld leg dimension for hot box-up (welded)
3. Basic clamp thickness calculations for cold clamp on ASME VIII and structural analysis against line pressure / injection pressure
4. Commonly available and used materials for clamps / pipe / lug have been listed along with their stress values against input temperature
5. Provides liberty to the user for input of all required data if not in scope of ClampOX material library
6. Provides all the required output which a design engineer would require
7. Detailed sketch of cold box-up with all required dimensions including:
a. Clamp thickness
b. Lug thickness
c. Lug length
d. Lug width
e. Weld led dimension for lug attachment
8. For bolted clamps, ClampOX generates the required bolt diameter and bolt spacing also however number of bolts have to be specified by user
9. General notes have been provided within the software for basic information of user
10. Free to use
You can get your FREE copy from the following link:
Regards,
Ashfaq
    @thebigk • Jul 21, 2011
    Just wondering - is it a freeware or a time limited free download?
  • ashfaqanwer
    @ashfaqanwer-X0CZPx • Jul 21, 2011
    It's a FREEWARE.
    No time limitations.
    Regards,
    Ashfaq
  • Vanlt
    @vanlt-z2kgCX • Dec 23, 2015
    ashfaqanwerDear friends,
    a. Clamp thickness
    b. Lug thickness
    c. Lug length
    d. Lug width
    10. Free to use
    Regards,
    Ashfaq
    Why it difficult to joint with your website, how to registration to download?
  • tran long
    @tran-long-OB6rWm • Apr 11, 2016
    Dear Sir,
    It seems that the software is not available an more from the link,
    Could you please give me another copy to my email #-Link-Snipped-# ?
    Thanks very much and best wishes !
  • tran long
    Could you please give me another copy of the software ?
  • tran long
    @tran-long-OB6rWm • Apr 25, 2016
    Anybody pls help
  • niman
    @niman-RTHJAs • Nov 1, 2017
    Dear Sir,
    Could you please give me another copy to my email nima.eternity#-Link-Snipped-##-Link-Snipped-# ?
