chock and throttle valve
jaspal rautela
jaspal rautela
@jaspal-rautela-yw5rJz Oct 21, 2024
what is function of chocke valve and throttle valve?
  • aarthivg
    aarthivg
    @aarthivg-HH344f Jun 14, 2012
    Throttle Valve is designed to function as a pressure control valve, and will handle pressure drops. It is used widely in gas gathering systems to regulate flow, CO2, and steam injection systems, as well as in low, medium, and high-pressure separators.
  • zaveri
    zaveri
    @zaveri-5TD6Sk Jun 17, 2012
    throttle valves are present in carburetors and are used for regulating the flow of fuel via the inlet manifold of the engine. the actuation of these valves are controlled by the movement of the accelerator pedal.
  • nibhani
    nibhani
    @nibhani-wLU5Ju Jun 23, 2012
    ch
    jaspal rautela
    choke valve is used to restrict the flow of air inside the engine or to create vaccume...and to work the engine in cold state...
