@ishan-nohePN • Oct 25, 2012
Both are similar in nature. But while calculating/ designing of shafts, we consider centroid. And while considering buoyancy and its effect, we take into account centre of mass (C.G).
Basically, Centre of mass is in 3D. Centroid(of a plane lamina) in 2D. -
@imme-jYUMt5 • Oct 25, 2012
"while considering buoyancy and its effect, we take into account centre of mass (C.G). "
can u explain it yr.
shaft is also a 3-d figure. isn't it. may b u r right but i m nt gatin ur explanation. -
The shaft is 3D but we design it lamina by lamina (in concept). It depends on applications like for considering the force and its effect we consider the involvement of mass hence use centre of mass. But while finding the metacentric height or diameter of shaft we concider centroid. -
@naveen94-i2rZMz • Nov 4, 2012
Ques-what is centroid and moment of inertia,what are its applications in engineering field. -
@iashishsarode-dzJrSM • Mar 24, 2015
Centroid is the artithmetic mean position of the object's shape.
Moment of inertia is the force required to rotate an object. in simple words it is the resistance offered by mass on account of its distribution about the rotational axis for the rotation.
