CE - Ultimate Project Ideas for Mechanical Engineering
Hello Mechanical Engineers,
Me too an mechanical engineer and i have got topics for my final year projects from my friends and i have posted some here..
If you found good something select one and go ahead...
MECHANICAL / PRODUCTION BASED PROJECTS
- Fabrication of Waste chill recovery heat exchanger
- Fabrication of Three axis hydraulic modern trailer
- Automatic boring mechanism for foundries
- Fabrication of friction Welding Machine
- Fabrication of Remote operated weapon system
- Fabrication of shot blasting machine
- Electronic assisted hydraulic braking system
- Fabrication of double drum wet grinder
- Fabrication of mantles defense
- Fabrication of sewage water treatment plant
- Automatic pneumatic vice and jack
- Fabrication of bucket wheel escalator
- D & F of Automatic Embossing Drilling Machine
- Fabrication of water cooler cum air conditioner
- Remote controlled motorized zip crane
- Fabrication of transformer heat reduction system
- Fabrication of furnace using infrared Lamp
- Fabrication of Soar Air conditioner
- Fabrication of Automatic multi point grease gun
- Fabrication of Turbo Super Charger for two wheeler
- Fabrication of Double axis Pneumatic JCB
- Compressed air production using Vehicle Suspensor
- Solar Powered Auto charging grinding machine
- Remote controlled tilting wheel chair for physically disable
- Fabrication of Abrasive Jet Machine
- Fully automated chapathi making machine
- Fabrication of Coin Separator Machine
- Fabrication of magneto-bearing system
- Automatic rotating table with sequence operating machine
- Automatic Double Axis Welding Machine
- Automatic Scrap Collecting Vehicle
- Pneumatic Operated three Axis Modern Trailer
- Fabrication of thermo-electric refrigerator
- Automatic Pneumatic Paper cup folding Machine
- Fabrication of air bag automation
- Mirror cutting machine by using compressed air with abrasive stone mixture
- Automatic bar feeding mechanism for hack saw machine
- Fabrication of Pneumatic Machining Time Reduction in Shaping machine
- Fabrication of Remote controlled Scrap Collecting Vehicle
- Remote controlled wheel chair cum bed
- Fabrication of Tube Rolling Machine
- Auto Indexing gear cutting attachment for pneumatic shaping Machine
- Fabrication of Spring Testing Machine
- Fabrication of hydro-pneumatic clamping system
- Fabrication of Spring End Grinding Machine
- Fabrication of Water Cooler cum Air Conditioner
- Automatic paint spraying pick and place Equipment
- Fabrication of Non-Conventional Air compressor
- Fabrication of Multi-Engine Compressor
- Fabrication of Vacuum conveyor for industrial Application
- Fabrication of Fully automated Drilling Machine
- Fabrication of Electric Two Wheeler with Rechargeable Battery
- Automatic Pneumatic Grinding Machine
- Accident preventing system for automatic pneumatic printing press
- Automatic pneumatic multi-purpose press
- D & F of Pneumatic Auto Feed Riveting Machine
- Fabrication of Pelton Wheel Turbine
- D & Fabrication of Pneumatic Material Handling Equipment
- D & F of Pneumatic Reciprocating Water Pumping System
- Fabrication of Electronic Hack Saw Machine
- Fabrication of Automatic typical Pipe Cutting Machine
- D & F of Automatic Coil Winding Machine
- Accident Avoiding System in Heavy Cutting Machine
- Fabrication of pipe thread cutting Machine
- Fabrication of Automatic punching/printing conveyor
- D & F of Involute Gear Profile Error Detector
- Digital Locking System for material handling Vehicle
- D & F of Multipurpose Pneumatic Pressing Machine
- Fabrication of Pneumatic High Speed Reciprocation Hack Saw Machine
- Fabrication of Pneumatic Drill Jig
- D & F of Automatic Lubrication Machine
- Fabrication Pneumatic Leaf-Cup Making Machine
- D & F of Chemical Powered System (CPS)
- D & F of Pneumatic Printing Press Machine
- Automatic Car Parking System for apartment Building
- Sensor Based Automatic paint marking machine for sprocket Industries
- Automatic Packing control machine for industrial application
- Design & Fabrication of Conveyor Automation
- Automatic accident avoiding system for machines
- Sensor Based Inspection Conveyor
- Automatic Visitor Guided with Material Handling Vehicle
- Self centering 4-jaw chuck for lathe
- Simple indexing stepper motor in shaper Machine
- Automatic Water level Sensing Crane
- Fabrication of Accident preventing system in cutting Machine
- PC based wireless material handling vehicle for industrial application
- Remote controlled Material handling crane
- Automatic Dish Washing Machine
- D & F of Hydraulic Press with Power Pack
- D & F of Gear type Injection Moulding Machine
- D & F of Scissor Platform with Hydraulic Power Pack
- Quick Lifting Jack with Gear Arrangement
- Fabrication of Multi-process Cutter
- Fabrication of Milling Attachment for Lathe
- Fabrication of potato chips making machine
- Fabrication of Ground Dryer
- Fabrication of Auto feed pneumatic Vice
- Fabrication of Hydraulic Pallet Truck
- D & F of Mini Hydraulic Press Machine
- D & F of Pneumatic Ramming Machine
- D & F of Pneumatic Auto Feed Drilling Machine
- Fabrication of Slotting Attachment in Drilling Machine
- Fabrication of Pneumatic Sheet Cutting Machine
- D & F of Manual Coil Winding Machine
- Fabrication of Automatic Foot Dust Cleaning Machine
- Automatic Power Saving Conveyor for Industrial Application
- Fabrication of Floor Cleaning Machine
- Fabrication of cylindrical Tapping Machine
- Fabrication of sand collecting Machine
- D & F of Pneumatic Auto Feed Punching and Riveting Machine
- Fabrication of Cam Operated Valve
- Fabrication of Pantograph Universal Gas Cutting Machine
- Fabrication of spring Loaded Fan
- Fabrication of Automatic Sofa Comports
- Fabrication of Pneumatic Quick return Mechanism
- Fabrication of Multi-speed gear box
- D & F of Pneumatic Auto Feed Punching Machine
- Fabrication of Automatic cold chamber Die Casting Machine
- Fabrication of Automatic Bottle Washing Machine
- D & Fabrication of Hydraulic Lift using Pressure Booster
- D & F of Pneumatic Multipurpose Press
- Automatic Break Failure and Engine Over Heating Indication
- Fabrication of Domestic Floor Mill
- Fabrication of Hybrid Vehicle
- D & Fabrication of Portable Slotting Machine
- Fabrication of Automatic Dish Washing Machine
- Fabrication of Pneumatic Multipurpose Machine
- D & Fabrication of Hydro-Pneumatic Vice using Pressure Booster
- Fabrication of Hydraulic Pipe Bending Machine
- Fabrication of Oil Pump Testing Equipment
- D & F of Scissor Platform Machine
- Fabrication of Sheet Rolling Machine
- Accident Avoiding System in Punching Machine
- D & F of Automatic Drilling and Tapping machine
- Fabrication of self feed Drilling Machine
- Fabrication of Miniature Lathe
- Fabrication of Multipurpose Sheet Metal Machine
- Fabrication of Automatic Spring Rolling Machine
- Fabrication of Motorized Sheet Rolling Machine
- Fabrication of Pneumatic Vice
- Automatic Birds scrarer Machine
- Fabrication of vegetable slice machine
- Fabrication of Impulse turbine
- Fabrication of switch board Cutter
- Fabrication of Francis Turbine
- Fabrication of Pedestal Spot welding Machine
- Fabrication of hydraulic hybrid system
- Fabrication of Oil pump testing Equipment
- Fabrication of Pedal Washing Machine
- Automatic potato chips making machine
- Fabrication of Miniature Boiler
- Portable Circular Saw Machine
- Pneumatic Operated Chapathi Making Machine
- Intelligent Motorized Wall Painting Crane
- Fabrication of Cylindrical grinding Machine
- Automatic high speed Bottle Washing Machine
- Fabrication of Hydro Coupling Mechanism
- Fabrication of Fiber Extracting Machine
- Fabrication of Hybrid System for home
- Fabrication of Revolving gate compressor
- Fabrication of Detra fan for Industrial Application
- Fabrication of Mini milling machine
- Automatic pneumatic welding robot
- Remote controlled air craft (Flying Model)
- Fabrication of Magnetic coolant filter
- Auto charging grinding machine with solar power
- D & F of Multi-Engine Air Compressor
- Fabrication of Steam Power Plant
- Combined hydraulic and disk break
- Fabrication of Sub-Marian (Model)
- Automatic Vegetable (or) Lemon Cutting machine
- Pneumatic Reciprocating Water Pumping System
- Design and Fabrication of Cam Vice
- Fabrication of Multi Nut Tightner
- D & F of Micro Boring Attachment
- D & F of Circular Cutting machine
- D & F of Screw Slotting Machine
- Fabrication of Copper Wire Cutting machine
- Fabrication of Rubber Melting Machine
- Fabrication of Mini Water Service Station
- Fabrication of Multi Drill Holder
- Fabrication of Special Purpose Tapping Machine
- Fabrication of Hydraulic Vice with Power Pack
- Fabrication of Pneumatic Slotting Machine
- Fabrication of High Speed Portable Pipe Cutting Machine
- Fabrication of Pneumatic Paper cup Making Machine
- Fabrication of Pneumatic Injection Moulding Machine
- Fabrication of Mini Hydraulic Hand Operated Zip Crane
- Fabrication of Lamination Machine
- Fabrication of Universal Tapping Machine
- Fabrication of Twin spindle Drill Holder
- Fabrication of Pneumatic Bearing Puller
- Fabrication of Marine Engine Model
- Fabrication of Dosai Maker
- Fabrication of Cold Chamber Die casting Machine
- Fabrication of Portable Service Unit
- D & F of Hydraulic Lift with Power Pack
- D & F of Activated Carbon Manufacturing Plant
- Fabrication of Pneumatic Bearing Press
- Fabrication of Pneumatic Auto Indexing Drilling Machine
- Fabrication of Brass Screw Threading And Tapping Machine
- Fabrication of Sensor Operated Pneumatic Automatic Punching Machine
- Fabrication of Sheet metal Cutting Machine
- Fabrication of Bending/Bend Removing Machine
- Fabrication of Rotary Vane Pump
- Fabrication of Concave Attachment in Shaper
- Fabrication of Plate Bending Machine
- Fabrication of Lawn Mover
- Fabrication of Sheet Straightening Machine
- Fabrication of U-Type, V-Type, L-type Angle Bending Machine
- Fabrication of Wood Turning Lathe Machine
- D & F of Hot and Cold Water Dispenser
- Conversion of tap or Salty bore well water into purest, tastiest bottled Quantity Drinking Water
- Fabrication of Home Floor Mill
- Fabrication of Vacuum Pump
- Fabrication of Radial Plunger Pump
- D & F of Abrasive Belt Grinder
- D & F of Pneumatic Slow & High Speed Drilling Machine
- D & F of Wall grove Cutting Machine
- Fabrication of hydraulic Disk Brake
- Fabrication of Automatic Steering Mechanism
- Fabrication of Pneumatic belt Conveyor
- D & F of Contour Turning Attachment for Lathe
- Shocks absorber testing Machine
- Energy Saving Light Arrangement
- Power Saving System for Lathe
- Automatic Pressure controller Cum Valve Open/Close Arrangement
- Automatic Gate Open/Close System
- Robot Controlled Vacuum Cleaner
- Automatic Moisture and Light Controlling System
- Automatic Vulcanizing Machine
- Paper Counting Machine
- Industrial Boiler Flame Remote Adjustment System
- D & F of Abrasive Cutting Machine
- Fabrication of Coir Making Machine
- Fabrication of Cylinder Block Boring Machine
- Fabrication of Road Marking Machine
- Fabrication of Bottling of sugarcane juice Machine
- Fabrication of Grass Cutting Machine
- Fabrication of lathe Coolant Pump with Fitting Arrangement
- Fabrication of Tool Post Grinder
- Fabrication of Motorized Screw Jack
- Fabrication of Rotary Kaller
- Fabrication of Escalator
- D & F of Injection Moulding Machine
- Fabrication of Maize de-Husker
- Fabrication of Hydro Power Plant
- Fabrication of Concave Attachment for Lathe
- Fabrication of Arbor Presses Machine
- Fabrication of Eccentric Press Machine
- Fabrication of Fly Press Machine
- Fabrication of level Operated conical bending Machine
- Fabrication of hand Operated edge Folding Machine
- Fabrication of Semi-Circular Cutting machine
- Fabrication of Hydraulic Hand Operated pipe Bending Machine
- Fabrication of Rotary Gear Pump
- D & F of Self primary Centrifugal Pump
- D & F of two stage Self Primary Pump
- Automatic Cylinder Boring Machine
- Automatic Motorized Door Open/Close Mechanism
- Motorized Focus Light Mechanism (In All Direction)
- Automatic Acrylic Sheet Bending Machine (Heater Control)
- Automatic Lamination Machine
- Mini Crushing Machine
- Electrical Spot Welding Machine
- Automatic Plant Water Moistering System for Garden
- Automatic Water level Indicator and Controlling System
- Aero plane Controlling System (Glider Model)
- Digital Controlled Coil Winding Machine
- Fabrication of Air Leak Detector
- Temperature Controller with Cooling System
- Fabrication of Spark Plug Tester
- Automatic pneumatic Gear Changer
- Automatic Dam Shutter Control System
- Portable Pipe Cutting machine
- Fabrication of Variable Drive Gear Box
- Fabrication of Motorized Crane
- Remote control Dish Antenna Tracking System
- Electric Two Wheeler with Rechargeable Battery (Foldable Type)
- Fabrication Folding Mobile with Gas and petrol
- Fabrication of Electronic Braking System
- Fabrication of Magnetic Iron Separator
- Fabrication of Mosaic Polishing Machine
- Fabrication of Sensor Operated Automatic Ramming Machine
- Fabrication of Pneumatic Multipurpose Grinder
- Fabrication of Pedestal Spot Welding Machine
- Motorized Wheel Chair for Physically Disabled
- Hydraulic Puller for Automobile Engines
- Fabrication of mist coolant system
- Fabrication of spring separator
- Fabrication of tomato Grader
- Fabrication of Air leak Detector
THERMAL REFREGERATION BASED PROJECTS
- Fabrication of thermo-electric solar air conditioner
- Water Cooler cum Air Conditioner
- Transformer heat reduction system
- Water cooler cum Water heater by using refrigeration System
- Remote controlled boiler flame adjustment system
- Fabrication of Automatic temperature controller with cooling system
- Fabrication of Hot and Cold Water Dispenser
- Fabrication of Solar air conditioning Machine
- Waste chill recovery heat exchanger
- Fabrication of Solar Air Conditioner
- Fabrication of Mist Coolant system
- Automatic Electro-plating coating process
- Fabrication of Solar Water Heater by using parabolic collector
- Electrical Power Generation using Thermal Power Plant
- Fabrication of Solar refrigeration system
- Fabrication of Bottle Cooler
- Fabrication of Solar Fridge
- Fabrication of Solar Kettle (or) Solar Parabolic Collector
- Fabrication of Solar Air Cooler
- Fabrication of Activated Carbon Manufacturing Plant
- Fabrication of Mini Water Heater
- Automatic pneumatic vulcanizing Machine using heat sensor
- Solar Water Purification by using thermal method
- Fabrication of Paper cup folding Machine
- Fabrication of Micro Wave Oven
- Fabrication of Solar Air Dryer
- Fabrication of Lube oil cooler
- Fabrication of double effecting solar cooker
- Fabrication of Solar Air Cooler cum Heater
- Fabrication of refrigeration system (trainer)
- Fabrication of L.L.D.P. Material extruder
- Fabrication of solar Water Heater
- Fabrication of double reflection solar Cooker
- Fabrication of Cooling tower
- Electrical Power Generation using Steam Power Plant
- Fabrication of Solar Water Disalation (Purification) by using parabolic method
- Multi-Purpose Ground Dryer (or) Multi-Purpose Dryer and Room Heater
- D & F of Chemical Processing Plant
- Fabrication of solar water disalation by using photovoltaic method
- Fabrication of automatic humidification system
All the Best for your Project. ๐
