CE - Ultimate Project Ideas for Computer Engineering
Hello,
I have got ton's of topics added regarding projects for computer engineering have a look below and choose a topic and go ahead..
๐
DATA MINING BASED PROJECTS
- Building a Multiple-Criteria Negotiation Support System
- An Exploratory Study of Database Integration Processes
- COFI approach for Mining Frequent Item sets
- Online Random Shuffling of Large Database Tables
- A Flexible Content Adaptation System Using a Rule-Based Approach
- Efficient Revalidation of XML Documents
- Practical Algorithms and Lower Bounds for Similarity Search in Massive Graphs
- Enhancing the Effectiveness of Clustering with Spectra Analysis
- Efficient Monitoring Algorithm for Fast News Alerts
- Top-k Monitoring in Wireless Sensor Networks
- Frequent Closed Sequence Mining without Candidate Maintenance
- Maintaining Strong Cache Consistency for the Domain Name System
- Efficient Skyline and Top-k Retrieval in Subspaces
- Efficient Process of Top-k Range-Sum Queries over Multiple Streams with Minimized Global Error
- Fast Nearest Neighbor Condensation for Large Data Sets Classification
- Wildcard Search in Structured Peer-to-Peer Networks
- Neural-Based Learning Classifier Systems
- Discovering Frequent Agreement Sub trees from Phylogenetic Data
- Watermarking Relational Databases Using Optimization-Based Techniques
- Extracting Actionable Knowledge from Decision Trees
- A Requirements Driven Framework for Benchmarking Semantic Web Knowledge Base Systems
- The Threshold Algorithm: From Middleware Systems to the Relational Engine
- Rank Aggregation for Automatic Schema Matching
- Rule Extraction from Support Vector Machines: A Sequential Covering Approach
- Efficient Computation of Iceberg Cubes by Bounding Aggregate Functions
- A Note on Linear Time Algorithms for Maximum Error Histograms
- Toward Exploratory Test-Instance-Centered Diagnosis in High-Dimensional Classification
- An Entropy Weighting k-Means Algorithm for Subspace Clustering of High-Dimensional Sparse Data
- A Method for Estimating the Precision of Place name Matching
- Efficiently Querying Large XML Data Repositories: A Survey
- Graph-Based Analysis of Human Transfer Learning Using a Game Tested
- Evaluating Universal Quantification in XML
- Customer Profiling & Segmentation using Data Mining Techniques
- Efficient Frequent Item set Mining Using Global Profit Weighted (GPW) Support Threshold
- Fast Algorithms for Frequent Item set Mining using FP-Trees
- Mining Confident Rules without Support Requirement
- Mining Frequent Item set without Support Threshold
- unified framework for utility based measures
- An Adaptation of the Vector-Space Model for Ontology-Based Information Retrieval
- The Google Similarity Distance
- Reverse Nearest Neighbors Search in Ad Hoc Subspaces
- Quality-Aware Sampling and Its Applications in Incremental Data Mining
- An Exact Data Mining Method for Finding Center Strings and All Their Instances
- Negative Samples Analysis in Relevance Feedback
- Bayesian Networks for Knowledge-Based Authentication
- Continuous Nearest Neighbor Queries over Sliding Windows
- The Concentration of Fractional Distances
- Efficient Approximate Query Processing in Peer-to-Peer Networks
- Ontology-Based Service Representation and Selection
- Compressed Hierarchical Mining of Frequent Closed Patterns from Dense Data Sets
- Semi-supervised Regression with Co-training-Style Algorithms
- Evaluation of Clustering with Banking Credit Card segment
- An efficient clustering algorithm for huge dimensional database
- Novel approach for Targeted Association Querying
- Hiding Sensitive Association Rules with Limited Side Effects
- A Relation-Based Search Engine in Semantic Web
- Classifier Ensembles with a Random Linear Oracle
- An Efficient Web Page Change Detection System Based on an Optimized Hungarian Algorithm
- Mining Nonambiguous Temporal Patterns for Interval-Based Events
- Peer-to-Peer in Metric Space and Semantic Space
- Adaptive Index Utilization in Memory-Resident Structural Joins
- On Three Types of Covering-Based Rough Sets
- Discovering Frequent Generalized Episodes When Events Persist for Different Durations
- Efficient and Scalable Algorithms for Inferring Likely Invariants in Distributed Systems
- Mining Closed Frequent item set using CHARM algorithm
- Integrating Constraints and Metric Learning in Semi-Supervised Clustering
- Foundational Approach to Mining Item set Utilities from Databases
- Fast Frequent Pattern Mining
- Evaluation for Mining Share Frequent item sets Containing Infrequent Subsets
IMAGE PROCESSING BASED PROJECTS
- An Efficient Phase and Object Estimation Scheme for Phase-Diversity Time Series Data
- A Recursive Model-Reduction Method for Approximate Inference in Gaussian Markov Random Fields
- LCD Motion Blur Reduction: A Signal Processing Approach
- A Lossless Compression Scheme for Bayer Color Filter Array Images
- Optimal Sensor Array Configuration in Remote Image Formation
- Image Classification Using Correlation Tensor Analysis
- Orthogonal Rotation-Invariant Moments for Digital Image Processing
- Generalized Flooding and Multicue PDE-Based Image Segmentation
- Maximum Likelihood Wavelet Density Estimation With Applications to Image and Shape Matching
- Weighted Adaptive Lifting-Based Wavelet Transform for Image Coding
- A Run-Based Two-Scan Labeling Algorithm
- Using Spanning Graphs for Efficient Image Registration
- Continuous Sampling in Mutual-Information Registration
- Universal Impulse Noise Filter Based on Genetic Programming
- Active Learning Methods for Interactive Image Retrieval
- Analysis and Compensation of Rolling Shutter Effect
- Automatic Active Model Initialization via Poisson Inverse Gradient
- FIR Filter Banks for Hexagonal Data Processing
- Wavelet Feature Selection for Image Classification
- Robust Control-Based Object Tracking
- Binary Partition Trees for Object Detection
- A Sparsity-Enforcing Method for Learning Face Features
- A Fast Multilevel Algorithm for Wavelet-Regularized Image Restoration
- Mode-kn Factor Analysis for Image Ensembles
- Preferential Image Segmentation Using Trees of Shapes
- A Shearlet Approach to Edge Analysis and Detection
- Study on Huber Fractal Image Compression
- Spherical Coding Algorithm for Wavelet Image Compression
- Multiple Description Coding With Prediction Compensation
- Signal and Image Approximation Using Interval Wavelet Transform
- Face Verification With Balanced Thresholds
- Optimal Signature Design for Spread-Spectrum Steganography
NETWORKING(MOBILE PHONE) BASED PROJECTS
- An Efficient Packet Scheduling Algorithm With Deadline Guarantees for Input-Queued Switches
- Scalability of Wireless Networks
- Class Bench: A Packet Classification Benchmark
- Fairness and Load Balancing in Wireless LANs Using Association Control
- Reliable Multi-path Provisioning for High-Capacity Backbone Mesh Networks
- Limitations of Equation-Based Congestion Control
- Performance Improvement of Two-Dimensional Packet Classification by Filter Rephrasing
- A Queuing-Theoretic Foundation of Available Bandwidth Estimation: Single-Hop Analysis
- Waveband Switching for Dynamic Traffic Demands in Multi-granular Optical Networks
- Distribution of Path Durations in Mobile Ad Hoc Networks and Path Selection
- Distributed Optimal Self-Organization in Ad Hoc Wireless Sensor Networks
- A Unified Framework for Max-Min and Min-Max Fairness With Applications
- On Shortest Path Representation
- A Network Calculus With Effective Bandwidth
- A Framework for Evaluating the Performance of Cluster Algorithms for Hierarchical Networks
- Distributed Algorithms for Secure Multi-path Routing in Attack-Resistant Networks
- Optimal Scheduling and Routing for Maximum Network Throughput
- Two Techniques for Fast Computation of Constrained Shortest Paths
- Improved Quasi-Path Restoration in Mesh Networks
- A Geometric Approach to Improving Active Packet Loss Measurement
- A Scalable Call Admission Control Algorithm
- Efficient Broadcasting Using Network Coding
- Statistical Techniques for Detecting Traffic Anomalies Through Packet Header Data
- A Model-Based Approach to Evaluation of the Efficacy of FEC Coding in Combating Network Packet Losses
- Faster Algorithms for Construction of Recovery Trees Enhancing QoP and QoS
- A Wavelet-Based Approach to Detect Shared Congestion
- Optimal Communication Complexity of Generic Multicast Key Distribution
- Reliable Routings in Networks With Generalized Link Failure Events
- Optimal and Distributed Protocols for Cross-Layer Design of Physical and Transport Layers in MANETs
- Traffic Modeling and Proportional Partial Caching for Peer-to-Peer Systems
- On Static and Dynamic Partitioning Behavior of Large-Scale P2P Networks
- Scalability of Network-Failure Resilience: Analysis Using Multi-Layer Probabilistic Graphical Models
- Maintaining Colored Trees for Disjoint Multi-path Routing Under Node Failures
- High-Performance Self-Routing Algorithm for Multiprocessor Systems with Shuffle Interconnections
- Optical Switching Networks with Minimum number of Limited Range Wavelength Converters
- Network implementation through port numbers
