@abrakadabra • Sep 24, 2010
@WIN: That's a nice initiative. I think we should focus on explaining the terms in simple words. Instead of copying the term's explanation from Wikipedia or 'n' number of websites, we should try to write in our own words in a way such that we are explaining that terminology or concept to our friends. That way we get to read original ideas and different ways of explanation.
Wow! This will be really useful 😀
Looking forward to this. -
@whats-in-name-KdgM7o • Sep 24, 2010
Explaining terminology in our own words will be really helpful.I completely agree with you.😀AbraKadabra@WIN: That's a nice initiative. I think we should focus on explaining the terms in simple words. Instead of copying the term's explanation from Wikipedia or 'n' number of websites, we should try to write in our own words in a way such that we are explaining that terminology or concept to our friends. That way we get to read original ideas and different ways of explanation.
So here we go.. -
IP Address:
It is used to identify a node(Computer connected to internet) on an IP(Internet Protocol) network.Each node is assigned a unique IP address which is a 32-bit address made up of network ID and unique host ID. -
@manish-r2Hoep • Sep 24, 2010
CE is itself a encyclopedia ,it has lot of information, but in unorganized form.
If anyone can create a reorganize it then it will be damn useful to others
Please don't discuss this here now
carry on with your work ,it is nice initiative -
Boot:
The process of starting or resetting a computer.When doing cold boot(First turned on) or warm boot(reset),the computer runs the software that loads and starts the computer's operating system. -
Buffer:
A space reserved in RAM,for data that is held temporarily while waiting,to be moved between two locations.
Eg: Data moved from keyboard to any particular application is first stored in buffer. -
@whats-in-name-KdgM7o • Oct 1, 2010
Print Spooler:
It is a software which receives the document sent to the printer,stores it in memory until printer is ready.
It manages all the print jobs.It allows user to delete,pause,restart print jobs which are currently in the queue. -
@whats-in-name-KdgM7o • May 5, 2011
CoDec:
Codec is a software which is use to compress or decompress a digital media file(Video or Audio).CoDec stands for Compressor/Decompressor or sometimes Coder/Decoder. -
@praveenkumar-66Ze92 • May 9, 2011
Modem
A modem (modulator-demodulator) is a device that converts the analog signal to digital, understood by computers and back to analog, which can be transferred via phone line, and connect to another server, which does the same operation. It is mostly used for internet purposes.
Wikipedia: A modem (modulator-demodulator) is a device that modulates an analog carrier signal to encode digital information, and also demodulates such a carrier signal to decode the transmitted information. The goal is to produce a signal that can be transmitted easily and decoded to reproduce the original digital data. Modems can be used over any means of transmitting analog signals, from light emitting diodes to radio.
Blog
A Blog is a combination of two words, namely Web Log. It is also a kind of website, which primarily used to have articles or posts, posted by the author or the public, with a small comments section in the end. It is mainly used for posting their views on some subject or sharing something to others. -
Forum
An Internet Forum is a type of website (Eg. CE Forums), where many users will be able to start a topic and discuss on it. The topics will be grouped into categories and sections, so that the posts relating to that section can be viewed by the users in an easy way. -
Netiquette
It is formed by clubbing two words, network etiquette, which is "Internet etiquette". It is a set of ways to behave yourself in the internet and social groups. Some good ones are, posting content in the right place and posting good and ethical content. Some wrong ones include spamming, flaming, and pointing out someone, getting inside his privacy in public. -
@whats-in-name-KdgM7o • May 10, 2011
Bitmap:
A bitmap is a simplistic representation of an image on a computer, simply indicating whether or not pixels are on or off, and sometimes indicating their color. Often fonts are represented as bitmaps. The term "pixmap" is sometimes used similarly; typically when a distinction is made, pixmap refers to color images and bitmap refers to monochrome images. -
@praveenkumar-66Ze92 • May 10, 2011
Raster and Vector Graphics
Raster is more of a photograph, with gradients, soft meshes, textures, etc. Not just spot color sharp lines. You could not cut out a raster image. Raster can be 1,2,3, or 4 colors which makes the entire spectrum (CMYK, RGB, HSL, etc.).
Vector graphics is the creation of digital images through a sequence of commands or mathematical statements that place lines and shapes in a given two-dimensional or three-dimensional space.
Vector graphics don't have any quality factor. i.e., at any size, the quality remains as such. No change in quality. This is the reason, vector graphics are used extensively in printing purposes.
Example of Raster and Vector Images (From Wikipedia)
@whats-in-name-KdgM7o • Jun 5, 2011
AIX:
AIX is an operating system developed by IBM and is in fact is Unix-based. It is typically used for enterprise servers.AIX allows the system administrator to divide memory, CPU, and disk access between various jobs. The system supports IBM's 64-bit POWER processor and is backwards-compatible with 32-bit applications.
Simply:
AIX is not your typical consumer operating system. It is mainly used for servers in large businesses where IT geeks get to work with it. -
Baseband:
Baseband refers to the original frequency range of a transmission signal before it is converted, or modulated, to a different frequency range. For example, an audio signal may have a baseband range from 20 to 20,000 Hz. When it is transmitted on a radio frequency (RF), it is modulated to a much higher frequency range. -
Heard of FIFO and LIFO,Whats GIGO:
GIGO:
Stands for "Garbage In, Garbage Out." It means that if invalid data is entered in a computer program, the resulting output will also be invalid.Because we computer users aren't always smart enough to enter valid data, programmers have to take extensive measures to prevent GIGO errors. -
@saijayadeep-5PFk4D • Jun 23, 2011
ya really this section helps us to gain knowledge and terms explained here is straight and crystal clear......niceeeeee -
@praveenkumar-66Ze92 • Jun 23, 2011
The Open Systems Interconnection model
The Open Systems Interconnection model (OSI model) is a way of sub-dividing a communications system into smaller parts called layers.
Layers
Layer 7: Application Layer
Layer 6: Presentation Layer
Layer 5: Session Layer
Layer 4: Transport Layer
Layer 3: Network Layer
Layer 2: Data Link Layer
Layer 1: Physical Layer -
@anoop-FRTf1L • Jul 7, 2011
RSS FEEDS:
RSS (originally RDF Site Summary, often dubbed Really Simple Syndication) is a family of <a href="https://en.wikipedia.org/wiki/Web_feed" target="_blank" rel="nofollow noopener noreferrer">Web Feed</a> formats used to publish frequently updated worksâsuch as <a href="https://en.wikipedia.org/wiki/Blog" target="_blank" rel="nofollow noopener noreferrer">Blog</a> entries, news headlines, audio, and videoâin a standardized format. An RSS document (which is called a "feed", "web feed"or "channel") includes full or summarized text, plus <a href="https://en.wikipedia.org/wiki/Metadata" target="_blank" rel="nofollow noopener noreferrer">Metadata</a> such as publishing dates and authorship.
Web feeds benefit publishers by letting them <a href="https://en.wikipedia.org/wiki/Web_syndication" target="_blank" rel="nofollow noopener noreferrer">Web Syndication</a> content automatically. They benefit readers who want to subscribe to timely updates from favored websites or to aggregate feeds from many sites into one place. RSS feeds can be read using <a href="https://en.wikipedia.org/wiki/Software" target="_blank" rel="nofollow noopener noreferrer">Software</a> called an "<a href="https://en.wikipedia.org/wiki/RSS_reader" target="_blank" rel="nofollow noopener noreferrer">Rss Reader</a>", "feed reader", or "<a href="https://en.wikipedia.org/wiki/News_aggregator" target="_blank" rel="nofollow noopener noreferrer">News Aggregator</a>", which can be <a href="https://en.wikipedia.org/wiki/Web_application" target="_blank" rel="nofollow noopener noreferrer">Web Application</a>, <a href="https://en.wikipedia.org/wiki/Application_software" target="_blank" rel="nofollow noopener noreferrer">Application Software</a>, or mobile-device-based. A standardized <a href="https://en.wikipedia.org/wiki/XML" target="_blank" rel="nofollow noopener noreferrer">Xml</a> file format allows the information to be published once and viewed by many different programs. The user subscribes to a feed by entering into the reader the feed's <a href="https://en.wikipedia.org/wiki/Uniform_Resource_Identifier" target="_blank" rel="nofollow noopener noreferrer">Uniform Resource Identifier</a> or by clicking a <a href="https://en.wikipedia.org/wiki/Feed_icon" target="_blank" rel="nofollow noopener noreferrer">Feed Icon</a> in a web browser that initiates the subscription process. The RSS reader checks the user's subscribed feeds regularly for new work, downloads any updates that it finds, and provides a <a href="https://en.wikipedia.org/wiki/User_interface" target="_blank" rel="nofollow noopener noreferrer">User interface - Wikipedia</a> to monitor and read the feeds. RSS allows users to avoid manually inspecting all of the websites they are interested in, and instead subscribe to websites such that all new content is pushed onto their browsers when it becomes available.
RSS formats are specified using XML, a generic specification for the creation of data formats.
<a href="https://en.wikipedia.org/wiki/RSS_feed" target="_blank" rel="nofollow noopener noreferrer">Rss Feed</a>
Wi-Fi (Wireless Fidelity) <a href="https://en.wikipedia.org/wiki/Wikipedia:IPA_for_English#Key" target="_blank" rel="nofollow noopener noreferrer">Wikipedia:ipa For English Key</a><a href="https://en.wikipedia.org/wiki/Wikipedia:IPA_for_English#Key" target="_blank" rel="nofollow noopener noreferrer">Wikipedia:ipa For English Key</a><a href="https://en.wikipedia.org/wiki/Wikipedia:IPA_for_English#Key" target="_blank" rel="nofollow noopener noreferrer">Wikipedia:ipa For English Key</a><a href="https://en.wikipedia.org/wiki/Wikipedia:IPA_for_English#Key" target="_blank" rel="nofollow noopener noreferrer">Wikipedia:ipa For English Key</a><a href="https://en.wikipedia.org/wiki/Wikipedia:IPA_for_English#Key" target="_blank" rel="nofollow noopener noreferrer">Wikipedia:ipa For English Key</a>is a wireless standard for connecting electronic devices. A Wi-Fi enabled device such as a personal computer, video game console, smartphone, and digital audio player can connect to the <a href="https://en.wikipedia.org/wiki/Internet" target="_blank" rel="nofollow noopener noreferrer">Internet</a> when within range of a <a href="https://en.wikipedia.org/wiki/Wireless_network" target="_blank" rel="nofollow noopener noreferrer">Wireless Network</a> connected to the Internet. A single <a href="https://en.wikipedia.org/wiki/Wireless_access_point" target="_blank" rel="nofollow noopener noreferrer">Wireless Access Point</a> (or <a href="https://en.wikipedia.org/wiki/Hotspot_%28Wi-Fi%29" target="_blank" rel="nofollow noopener noreferrer">Hotspot %28Wi Fi%29</a>) has a range of about 20 meters (65 feet) indoors. Wi-Fi has a greater range outdoors and multiple overlapping access points can cover large areas.
<a href="https://en.wikipedia.org/wiki/Wi-Fi" target="_blank" rel="nofollow noopener noreferrer">Wi Fi</a>
@praveenkumar-66Ze92 • Jul 7, 2011
Wireless Application Protocol - WAP
The Wireless Application Protocol (WAP) is an open, global specification that empowers mobile users with wireless devices to easily access and interact with information and services instantly.
Purpose: To enable easy fast delivery of relevant information and services to mobile users.
Target Devices: Handheld digital wireless devices such as mobile phones, pagers, two-way radios, smartphones and communicators -- from low-end to high-end.
Networks: WAP is designed to work with most wireless networks such as CDPD, CDMA, GSM, PDC, PHS, TDMA, FLEX, ReFLEX, iDEN, TETRA, DECT, DataTAC, Mobitex and GRPS.
Operating System: WAP is a communications protocol and application environment. It can be built on any operating system including PalmOS, EPOC, Windows CE, FLEXOS, OS/9, JavaOS etc. It provides service interoperability even between different device families. -
WPA (Wi-Fi Protected Access)
WPA (Wi-Fi Protected Access) is an interim standard by the WiFi Alliance to comply with the security protocol designed for wireless security. WPA will most likely be rolled into an eventual IEEE 802.11i standard. This protocol was an outcome of numerous severe flaws researchers had discovered in the preceding wireless security system called Wired Equivalent Privacy (WEP).
History
Wi-Fi Alliance launched in October 2003 the next generation in WLAN security - Wi-Fi Protected Access – WPA. 802.11 equipment do not require a hardware upgrade to support Wi-Fi Protected Access. You only need to upgrade software and firmware, and it makes only minimal degradation in a network performance.
WPA was designed as WEP replacement and answer to all WEP weaknesses. It uses Temporal Key Integrity Protocol (TKIP) with Message Integrity Check (MIC). It also has mutual pre-shared key (PSK) authentication scheme using 802.11X/EAP.
WI-Fi Alliance launched WPA2 in September 2004. It is certified interoperable version of the WPA. WPA2 beside PSK 802.1X/EAP authentication, use an advanced encryption mechanism. This new mechanism is Counter-Mode/CBC-MAC Protocol (CCMP) called Advanced Encryption Standard (AEP).
Types
WPA and WPA2 have two certification modes:
- Enterprise
- Personal -
@whats-in-name-KdgM7o • Jul 13, 2011
BlackList:
A blacklist is list of items, such as usernames or IP addresses, that are denied access to a certain system or protocol. When a blacklist is used for access control, all entities are allowed access, except those listed in the blacklist. The opposite of a blacklist is a whitelist, which denies access to all items, except those included in the list.
Web servers often include a blacklist that denies access from specific IP addresses or ranges of IPs, for security purposes. -
BOOT Sector:
The boot sector is a dedicated section of a hard disk or other storage device that contains data used to boot a computer system. It includes the master boot record (MBR), which is accessed during the boot sequence.
The boot sector is typically located at the very beginning of a disk, before the first partition. It includes the partition map, which identifies all the partitions on the disk. It also defines which partition contains the startup data (such as the operating system). This lets the computer know which partition to access when starting up. Therefore, if a disk's boot sector becomes corrupted or contains invalid data, the computer may not be able to start up from the disk. If this happens, you should run a disk utility or antivirus program to try and fix the problem. -
@praveenkumar-66Ze92 • Jul 13, 2011
CMOS
Short for complementary metal oxide semiconductor. Pronounced see-moss, CMOS is a widely used type of semiconductor. CMOS semiconductors use both NMOS (negative polarity) and PMOS (positive polarity) circuits. Since only one of the circuit types is on at any given time, CMOS chips require less power than chips using just one type of transistor. This makes them particularly attractive for use in battery-powered devices, such as portable computers. Personal computers also contain a small amount of battery-powered CMOS memory to hold the date, time, and system setup parameters. -
LCD
Short for liquid crystal display, a type of display used in digital watches and many portable computers. LCD displays utilize two sheets of polarizing material with a liquid crystal solution between them. An electric current passed through the liquid causes the crystals to align so that light cannot pass through them. Each crystal, therefore, is like a shutter, either allowing light to pass through or blocking the light. -
TFT
Short for thin film transistor, a type of LCD flat-panel display screen, in which each pixel is controlled by from one to four transistors. The TFT technology provides the best resolution of all the flat-panel techniques, but it is also the most expensive. TFT screens are sometimes called active-matrix LCDs. -
BIOS
Acronym for basic input/output system, the built-in software that determines what a computer can do without accessing programs from a disk. On PCs, the BIOS contains all the code required to control the keyboard, display screen, disk drives, serial communications, and a number of miscellaneous functions.
The BIOS is typically placed in a ROM chip that comes with the computer (it is often called a ROM BIOS). This ensures that the BIOS will always be available and will not be damaged by disk failures. It also makes it possible for a computer to boot itself. Because RAM is faster than ROM, though, many computer manufacturers design systems so that the BIOS is copied from ROM to RAM each time the computer is booted. This is known as shadowing.
Many modern PCs have a flash BIOS, which means that the BIOS has been recorded on a flash memory chip, which can be updated if necessary.
The PC BIOS is fairly standardized, so all PCs are similar at this level (although there are different BIOS versions). Additional DOS functions are usually added through software modules. This means you can upgrade to a newer version of DOS without changing the BIOS.
PC BIOSes that can handle Plug-and-Play (PnP) devices are known as PnP BIOSes, or PnP-aware BIOSes. These BIOSes are always implemented with flash memory rather than ROM. -
@jeffrey-xA7lUP • Oct 28, 2012
Wow on earth did this thread die out Lots of Info here to cherish Thanks for starting this #-Link-Snipped-# Hope new members tag in here and enrich this list -
@zaveri-5TD6Sk • Nov 17, 2012
Principal stress
The stress that acts purely along any one of the principal axes, (x, y or z). -
@whats-in-name-KdgM7o • Jan 9, 2013
Android Beam:
It is a feature that enables android based devices to share content with other NFC-capable devices by simply touching the devices together and pressing a button on the device sending the content. It can be use to transfer photos, web pages and links, contact details, videos and more between devices.
In order to engage Beam(transfer), you need a phone with near field communication (NFC)capabilities.
What is NFC?
As wiki says,
Near field communication (NFC) is a set of standards for <a href="https://en.wikipedia.org/wiki/Smartphone" target="_blank" rel="nofollow noopener noreferrer">Smartphone</a> and similar devices to establish <a href="https://en.wikipedia.org/wiki/Radio" target="_blank" rel="nofollow noopener noreferrer">Radio</a> communication with each other by touching them together or bringing them into close proximity, usually no more than a few centimeters.
NFC is an upgrade of the existing RFID standard that combines the interface of a smartcard and a reader into a single device. It allows users to share content between digital devices.
The significant advantage of NFC over Bluetooth is the shorter set-up time. Instead of performing manual configurations to identify Bluetooth devices, the connection between two NFC devices is established at once (under a 1/10 second).
Due to its shorter range, NFC provides a higher degree of security than Bluetooth and makes NFC suitable for crowded areas where correlating a signal with its transmitting physical device (and by extension, its user) might otherwise prove impossible.
NFC can also work when one of the devices is not powered by a battery (e.g. on a phone that may be turned off, a contactless smart credit card, etc.).
Source:Internet -
@abhishek-fg9tRh • Jan 12, 2013
We CEans,back then once debated over NFC in "Weekend Technical Discussion" in lil depth.
check this out : #-Link-Snipped-# -
@whats-in-name-KdgM7o • Jan 13, 2013
I didn't knew that we are having scheduled technical discussions on CE,I would love to become the part of next one😀 -
@jeffrey-xA7lUP • Jan 14, 2013
Well the problem is due to several reasons we could not continue itWhats In NameI didn't knew that we are having scheduled technical discussions on CE,I would love to become the part of next one😀 -
@whats-in-name-KdgM7o • Jan 15, 2013
Lets start the discussions again,plan a new one.ConquerorWell the problem is due to several reasons we could not continue it -
@abhishek-fg9tRh • Jan 15, 2013
Hey WIN,I'm all ready.Whats In NameLets start the discussions again,plan a new one.
Check this post : #-Link-Snipped-#
It was strictly EC field discussions but then we tried to cover other Engineering branches too,sadly didn't got much response from other branch CEans.So,sadly we gotta stop it.
If you've any suggestion then please post in the given link so we can resurrect the event 😀
