CE Board Exam- Hydraulics and Geotech Review Problems
maria flor
@maria-flor-8cAkif Oct 21, 2024
-A confined aquifer is shown. This aquifer has a source of recharge located as shown. The hydraulic conductivity of the aquifer is 40m/day with porosity of 25%. The piezometric (head) surface in the two observation wells 1250m apart are at elevation 65m and 60m, respectively from the common datum. The aquifer has an average thickness of 25m and an average width of 4km.
[​IMG]
1. Determine the nearest value to the rate of flow of water through the aquifer, in cubic meters per day.
A. 14,000
B. 16,000
C. 18,000
D. 15,000
2. Determine the nearest value to the seepage velocity in m/day.
A. 0.76
B. 0.42
C. 0.54
D. 0.64
3. Determine the nearest value to the time of travel from the head of aquifer to a point 3.4km downstream, in days.
A. 4876
B. 6325
C. 5313
D. 5874
-A 4.2m thick layer of sand is underlain by a layer of clay. The water table is 2m below the ground (sand) surface. For sand, Gs = 2.65 and the average void ratio is 0.52. The sand above water table has a degree of saturation of 0.37. The saturated nit weight of the clay layer is 20.2 kN/m3.
[​IMG]
1. Determine the unit weight of sand above water table in kN/m3
A. 17.86
B. 20.46
C. 10.65
D. 18.35
2. Determine the total stress at a point 10m below the ground.
A. 199 kPa
B. 123 kPa
C. 232 kPa
D. 167 kPa
3. Determine the effective stress at a point 10m below the ground.
A. 134.5 kPa
B. 120.4 kPa
C. 156.9 kPa
D. 111.1 kPa
  • maria flor
    @maria-flor-8cAkif Jul 9, 2011
    The pump shown draws 25 liters per second of water from reservoir A and lifts it to reservoir B. The head lost from A to 1 is three times the velocity head in the 150-mm pipe and from 2 to B is ten times the velocity head in the 100-mm pipe.
    [​IMG]
    1. What is the nearest value to the power output of the pump in kilowatts?
    A. 78.3
    B. 69.6
    C. 54.1
    D. 60.2
    2. What is the nearest value to the pressure at point 1 in kilopascals?
    A. 154.2
    B. 168.9
    C. 230.4
    D. 192.2
    3. What is the nearest value to the pressure at point 2 in kilopascals?
    A. 2596
    B. 2678
    C. 2134
    D. 3112
    -An open cylindrical tank 30 cm in diameter and 80cm tall is filled with water and revolved about its own vertical axis at constant angular speed.
    [​IMG]
    1. What angular speed will cause 1.4 liters of water to spill?
    A. 45.5 rpm
    B. 87.2 rpm
    C. 65.2 rpm
    D. 56.1 rpm
    2. What will be the depth of water in the tank when it is brought to rest from an angular speed of 240 rpm?
    A. 0.438 m
    B. 0.672 m
    C. 0.321 m
    D. 0.552 m
    3. What angular speed will just zero the pressure at the bottom?
    A. 269.3 rpm
    B. 252.2 rpm
    C. 189.4 rpm
    D. 298.3 rpm
  • Prince Salazar
    @prince-p9UoSA Nov 19, 2018
    This is a great for us, espesicially for me as a student.
