  • nenuadwani
    @nenuadwani-pb4lOD • Oct 24, 2010
    causal systems are the systems which give the output based on the previous and present inputs. these systems do not have output dependency on the outputs after a specific time interval and this time interval depends on the system requirements.
  • d_vipul
    @d-vipul-wP6Syg • Oct 25, 2010
    Hey all,
    where it is used????? and why?????
    Please some one tell me..............
    Regards,
    VIPUL
  • arjuna
    @arjuna-tZoDLJ • Oct 25, 2010
    it is used....in signal processing.... analog or digital...
    u take example lpw pass filter....go through it...u'll...get ur answer... ๐Ÿ˜€
  • d_vipul
    @d-vipul-wP6Syg • Oct 26, 2010
    Thanks......
    Regards,
    VIPUL
  • Munguti
    @munguti-MnxkmE • Oct 26, 2010
    nenuadwanicausal systems are the systems which give the output based on the previous and present inputs. these systems do not have output dependency on the outputs after a specific time interval and this time interval depends on the system requirements.
    In Causal systems the output at a discreet time n1 depends on present inputs(at n1) and past inputs(n<n1) but not future inputs(n>n1). This might confuse you but you should realise that some sytems work on stored data and hence at a specific time they know what the future input will be.
  • nenuadwani
    @nenuadwani-pb4lOD • Oct 27, 2010
    how are these systems used in signal processing
  • Munguti
    @munguti-MnxkmE • Nov 3, 2010
    Digital filters that are not real time, speech sythesis, speech recognition
