@thebigk • Sep 17, 2012
MBA helps more if you've some work experience. But that shouldn't stop you from starting your preparation for the CAT. You're currently in 2nd year and I think you can only appear for the CAT when you're in final year. So I'd suggest that you should go through the CAT syllabus and check the level of difficulty. Once you're familiar with the CAT pattern, you can then start focusing on your weak areas and also work on your stronger areas.
Slow and steady wins the race. All the best! -
Sairam_007 OP
@sairam-007-8Sf0Lw • Sep 17, 2012
sure will do it..thanks for those kind words ๐
