@shailaja-tiwari-lKhGjd • Jan 19, 2014
Rajni JainHave courage to solve?
If you can, let's see how much time did you take to resolve this.
2+3=8,
3+7=27,
4+5=32,
5+8=60,
6+7=72,
7+8=??
Solve it?answer is 98..
time taken : 2 minutes 3 sec including typing part -
@rajni-E46Rlm • Jan 19, 2014
Shailaja Tiwarianswer is 98..
time taken : 2 minutes 3 sec including typing partwhat about explanation?
Rajni Jainwhat about explanation?
actually I left the explanation part so as not to spoil the sport for other members who would try to solve the question.....
anyway ,if it's expected then here's it
1*2+2*3=8
2*3+3*7=27
3*4+4*5=32
4*5+5*8=60
5*6+6*7=72
hence 6*7+7*8=98๐
since all the nos are in sequence , fisrt operands are multiplied by 1....onwards and then both the operands are multiplied with each other and consequently added together.....๐ -
Shailaja Tiwari1*2+2*3=8
2*3+3*7=27 <----
3*4+4*5=32
4*5+5*8=60
5*6+6*7=72
hence 6*7+7*8=98๐Couldn't understand this '7' ... infect all of the red ones.
Rajni JainCouldn't understand this '7' ... infect all of the red ones.
see it's simple :
2*3=6
+ 3*7=21
6+21=27
is it this that u wanted to know? or probably u might be thinking that the nos marked red aren't in sequential fashion....but that insequentiality is a part of ur challenge...๐ -
Shailaja Tiwarisee it's simple :
2*3=6
+ 3*7=21
6+21=27
is it what u wanted to know? or probably u might be thinking that the nos marked red aren't in sequential fashion....but that insequentiality is a part of ur challenge...๐He He He... Good One.
Non Sequential numbers.....3, 7, 5, 8, 7...
what make you think that next non-sequential number should be 8 to make answer as 6*7+7*8=98 ? -
Rajni JainHe He He... Good One.
what make you think that next non-sequential number should be 8 to make answer as 6*7+7*8=98 ?it was there in ur question itself......and knew that it's right ...i had to insert only 6 in the structure ....that's why i have formatted the manually entered numbrs as bold...
98 is the correct answer.
@sarathkumar-FEGRPw • Jan 19, 2014
Hi i tried for 20 minutes and failed but my friend found it in five minutes.
his answer:98
Explanation :
1)Add the two numbers
2)Multiply the answer with first digit and subtract the same digit to answer.
example :2+3=8
1)2+3=5
2)5*2=10
3)10-2=8 -
@midhun-mohan-qyNaHS • Feb 22, 2014
2 min 10 sec
answer is 98...
i found answer by the following,
(2*3)+(2*1)=8
(3*7)+(3*2)=27
(4*5)+(4*3)=32
(5*8)+(5*4)=60
(6*7)+(6*5)=72
here 1,2,3,4..etc are the order of equations
so
7+8=(7*8)+(7*6)=98
