Can you find an efficient solution to this bit manipulation problem?
eternalthinker
@eternalthinker-Kvsi5Y โ€ข Oct 21, 2024
The problem at hand is to map a number pair to a binary map:
For a length of 5,
Map (1,5) to 01110
Map (1,4) to 01100
Map (2,4) to 00100
and so on.
You can use any binary operators and the binary representations of given number limits (obviously).
I am trying to find an optimum solution with minimal looping and more intelligent use of binary operations. Can you try?!
Update: more explanation
For a length of 5, consider a row like this:
(_ is empty space and * is occupied space)
Now, for the above row, the indices of occupied spaces are:
(2,5)
Suppose we're representing
  • the empty spaces between *'s by 1's
  • all the rest by 0's (Note that 0's in the right side matter!)
Thus: _ * _ _ * maps to (2,5) maps to 00110
_ * * _ _ maps to (2,3) maps to 00000
I think that's clear now!
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • Dec 21, 2011
    What is the language you are trying to implement? Coz, in PHP it is very easy! ๐Ÿ˜€
  • eternalthinker
    @eternalthinker-Kvsi5Y • Dec 22, 2011
    @Praveen
    Bit operations shouldn't be very different throughout languages, I suppose.
    Or does PHP have any special operators which makes the solution easier?
    In any case, do share your solution ๐Ÿ˜€
    @praveenkumar-66Ze92 • Dec 22, 2011
    eternalthinker@Praveen
    PHP has associative array technique, which makes declaration of 2D Arrays / Maps easier... ๐Ÿ˜€
    For eg., consider this program: <?php
    ย ย ย ย $nย
    =ย 5;
    ย ย ย ย
    $aย =ย array();
    ย ย ย ย for(
    $iย =ย 0;ย $iย <ย $n;ย $i++)
    ย ย ย ย ย ย ย ย for(
    $jย =ย 0;ย $jย <ย $n;ย $j++)
    ย ย ย ย ย ย ย ย ย ย ย ย
    $a[$i][$j]ย =ย decbin($iย +ย $j);
    ย ย ย ย
    var_dump($a);
    The output is
    array(5) {
      [0]=>
      array(5) {
        [0]=>
        string(1) "0"
        [1]=>
        string(1) "1"
        [2]=>
        string(2) "10"
        [3]=>
        string(2) "11"
        [4]=>
        string(3) "100"
      [1]=>
      array(5) {
        [0]=>
        string(1) "1"
        [1]=>
        string(2) "10"
        [2]=>
        string(2) "11"
        [3]=>
        string(3) "100"
        [4]=>
        string(3) "101"
      [2]=>
      array(5) {
        [0]=>
        string(2) "10"
        [1]=>
        string(2) "11"
        [2]=>
        string(3) "100"
        [3]=>
        string(3) "101"
        [4]=>
        string(3) "110"
      [3]=>
      array(5) {
        [0]=>
        string(2) "11"
        [1]=>
        string(3) "100"
        [2]=>
        string(3) "101"
        [3]=>
        string(3) "110"
        [4]=>
        string(3) "111"
      [4]=>
      array(5) {
        [0]=>
        string(3) "100"
        [1]=>
        string(3) "101"
        [2]=>
        string(3) "110"
        [3]=>
        string(3) "111"
        [4]=>
        string(4) "1000"
    And, for this code: <?php
    ย ย ย ย $nย
    =ย 5;
    ย ย ย ย
    $aย =ย array();
    ย ย ย ย for(
    ย ย ย ย for(
    ย ย ย ย {
    ย ย ย ย ย ย ย ย ย ย ย ย echoย
    $a[$i][$j]ย .ย "\t";
    "\n";
    ย ย ย ย }
    The output is
    0       1       10      11      100
    1       10      11      100     101
    10      11      100     101     110
    11      100     101     110     111
    100     101     110     111     1000
    Did I understand your problem rightly?
    @ET: Finally you can arrive the same solution of yours in this way: <?php
    ย ย ย ย $nย
    =ย 5;
    ย ย ย ย
    $aย =ย array();
    ย ย ย ย for(
    ย ย ย ย for(
    "Mapย ($i,ย $j)ย isย {$a[$i][$j]}\n";
    And the output for the same is:
    Map (0, 0) is 0
    Map (0, 1) is 1
    Map (0, 2) is 10
    Map (0, 3) is 11
    Map (0, 4) is 100
    Map (1, 0) is 1
    Map (1, 1) is 10
    Map (1, 2) is 11
    Map (1, 3) is 100
    Map (1, 4) is 101
    Map (2, 0) is 10
    Map (2, 1) is 11
    Map (2, 2) is 100
    Map (2, 3) is 101
    Map (2, 4) is 110
    Map (3, 0) is 11
    Map (3, 1) is 100
    Map (3, 2) is 101
    Map (3, 3) is 110
    Map (3, 4) is 111
    Map (4, 0) is 100
    Map (4, 1) is 101
    Map (4, 2) is 110
    Map (4, 3) is 111
    Map (4, 4) is 1000
    This one is identical to what you asked! ๐Ÿ˜€
  • eternalthinker
    @eternalthinker-Kvsi5Y • Dec 23, 2011
    @Praveen
    I like the idea of storing all the patterns in an array once, and only referring to it subsequently.
    Anyhow, did you check the bit patterns in the question? There is a particular logic in how they are arranged.
    I think I should've been more clear in the question!
    Please see the updated question ๐Ÿ˜€
    @praveenkumar-66Ze92 • Dec 23, 2011
    I couldn't see the update buddy. Say once more na?
  • eternalthinker
    @Praveen
    I was updating it now! Check it again.
    Okay, got it... Gimme some time... Will do something.. ๐Ÿ˜
