Can you explain these c codes?
1. It seems pointer work is suspicious in the following code however it prints the result successfully. Please tell me why this program not gives error.
char *fun(){
char *temp = "Crazy Engineers";
return temp;
int main(){
puts(fun());
}2. What is the meaning of the +i in the following code? What will be the output? The program don't give a compiler error.
main(){
int i=-1;
+i;
printf("%d %d",i,+i);
3. What function of x and n is computed by the code segment? And the answer is x^n.
Can you explain how to calculate it quickly?
int foo ( int x , int n){
int val=1;
if(n>0){
if (n%2 == 1) val = val *x;
val = val * foo(x*x , n/2);
return val;
}4. The output of the following program is "Hell". Can you explain how?
main (){
unsigned i=3;
cirscr();
if(i>-1)
printf("Hell');
else
printf("Heaven");
}5.The output of the following program is 256. Can you tell me how?
main(){
unsigned char i=0x80;
printf("\n%d",i<<1);
}6.The output of the following code is "ligent". Can you explain why?
main(){
printf(5+"Intelligent");
}7. What will be the output of the following program? It is given as 2 5. Why a+1 don't give an error?
main(){
int a[5] = {1,2,3,4,5};
int *ptr = (int*)(&a+1);
printf("%d %d" , *(a+1),*(ptr-1));
