Can we reduce the amount carbon monoxide and nitric oxide emitted from car?
SOUNDHER RAJAN S
@soundher-rajan-AhdklL • Oct 26, 2024
Is there is any way to control carbon monoxide instead of using charcoal. Im doing this as project - To overcome carbon monoxide and nitric oxide
    @thebigk • Aug 7, 2018
    #-Link-Snipped-# - That looks like an interesting project to work on. Have you researched and found out ways? If not, that'd be the first step. Second step would be to discuss your observations so that we can help you.
    @ramani-VR4O43 • Aug 7, 2018
    As far as I am aware activated charcoal does not absorb Carbon Monoxide. Lower cost catalysts using cheaper copper or palladium may work in the place of the expensive platinum catalysts.
  • SOUNDHER RAJAN S
    @soundher-rajan-AhdklL • Aug 8, 2018
    No #-Link-Snipped-# sir keep searching only. Once I found I will inform u sir
  • SOUNDHER RAJAN S
    #-Link-Snipped-# Sir. Is there is any element for absorbing carbon monoxide or some others agents
    @anoop-SlERLg • Aug 8, 2018
    See this: #-Link-Snipped-#
    Bengaluru based startup has made a prototype to seize exhaust pollution from car and moterbikes.
  • John Wesley Jayakumar
    @john-wesley-RKLXtM • Aug 8, 2018
    1 Maybe we can use some chemicals which absorb the harmful gases .  Chemicals like zeolites , platinum which absorb black smoke which can be used in exhaust of bikes .
    2 we could use pure fuels with less or  no hydrocarbon content in it.
    3 Invent some methods to avoid incomplete combustion in power stroke ...... Etc
    @ramani-VR4O43 • Aug 8, 2018
    #-Link-Snipped-# some copper salts can absorb CO.
