Can I Add Extra RAM In Another RAM Slot Or I Have To Replace Existing RAM ?
i have a pre-installed 1gb ram which i feel it as insufficient, so i have decided to buy a 2gb ram ...is it possible to add a extra ram as i have two slots allocated for it or we can only replace it ? anybody give suggestions !!!
    @abhishek-fg9tRh • Sep 24, 2013
    You can add extra one & mount it on other slot.
    Edit : Moved to proper section.
    @anoop-kumar-GDGRCn • Sep 24, 2013
    Abhishek RawalYou can add extra one & mount it on other slot.
    In addition:
    You need to check compatibility of your current RAM with new RAM.
    both RAM should have same frequency and with version (DDRx)
    See in this image DDR3-1600 (ram version-Frequency in MHz)
    [​IMG]
    If your older current RAM is DDR2 and less frequency (<1000 Mhz), check if your mother supports better RAM then go for totally new RAM.
  • Brainy
    @brainy-JRemXE • Sep 24, 2013
    Also before you buy the ram make sure you check the ram slot on your motherboard to know if it is sd ram, ddr1, 2 or 3. So that will not buy the wrong one.
