@trex-5S6KCn • Feb 28, 2010
Here are a few examples of the math,,,,,, What is the force required from an actuator to move a 28 pound bracket across a metal table if the coefficient of sliding friction is 0.28? Another,,, a pneumatic cylinder must lift a 14 pound weight a distance of 6 inches, the inertial load is calculated to be 10.5 pounds, what approximate minimum force should be specified for the cylinder in this application?๐๐
@trex-5S6KCn • Mar 2, 2010
Can someone see if this is right? A continous- duty compressor supplies 35 scfm to a pneumatic system at 80 psig, what is the minimum size receiver that should be used? The choices are A- 6.4 gallon,,, B- 35.0 gallon,,,, C- 40.7 Gallon and D- 80 gallon,,,, I came up with C- 40.7 gallon. What you say??๐
