@abhishek-fg9tRh • Oct 17, 2012
It's a report generation program which allows programmer to create reports from data sources with very less written code.
For more detail
and #-Link-Snipped-# -
@simplycoder-NsBEdD • Oct 19, 2012
You can also refer SSRS (SQL Server Reporting Services). as an alternative.
@umesh-kumar-rai-BBwnLk • Nov 6, 2012
Crystal Report is a reporting tool which can be used to generate reports using various data sources. Here very less programming skill is required though you must have knowledge of database which is used to pull the data and manipulate it according to the requirement. Similar reporting tool Microsoft SQL Reporting Services, Business Objects, etc.
@abrakadabra • Nov 6, 2012
Crystal Reports is a business intelligence application used to design and generate reports from a wide range of data sources. It came integrated with Visual Studio versions prior to 2010. For Visual Studio 2010, it is still available as add-on software. ๐
