Can anyone Design Power Supply for me
Harshad Italiya
@harshad-ukH5ww โ€ข Oct 16, 2024
Hi Ceans,
I Want to Design one Power Supply..
My Requirement is....
500 ma Current
Need 7.5 and 5 Volt DC.
My Input is 12 Volt AC.
Can any one Design such for me please.
  • raj87verma88
    @raj87verma88-ZpL2Wn • Mar 18, 2009
    Godfather, I hope this is not a part of your project or assignment. And you know the forum rules. Do it yourself, share it here. You will get help whenever you are stuck somewhere. You already know, "No free lunches"
    @harshad-ukH5ww • Mar 18, 2009
    yes Raj i know Rules so here is my problem that
    the power supply right now i am using drops 500 ma current but it heats up whole circuit i want to remove it.
    will post the circuit diagram soon ๐Ÿ˜‰
  • sauravgoswami
    @sauravgoswami-UAfTlI • Mar 18, 2009
    use larger capacity capacitors and check out the datasheets of your components used!!!
  • just2rock
    @just2rock-DkmPtO • Mar 18, 2009
    yah,alongwith check the reverse circuit path.Maximum time this causes heat generation
    @harshad-ukH5ww • Mar 19, 2009
    Well if i use large capacity Capacitor at that time it losses the count value of my ADC.
  • sauravgoswami
    @sauravgoswami-UAfTlI • Mar 19, 2009
    buddy, isolate your power supply from the ADC,use a regulator IC to provide controlled supply,power supply should not be afected from any component unless theres a bad-connection or fault occurence.
  • reachrkata
    @reachrkata-FOcqhH • Mar 22, 2009
    Regarding the heating up, I would advise a relook into your design. If you are using Linear design, you would have close to 2.8W of dissipation in the power supply (assuming 250mA each for 7.5V and 5V). Thats too much heat.
    I would advise shifting to a switching design.
    -Karthik
    @harshad-ukH5ww • Mar 24, 2009
    reachrkataRegarding the heating up, I would advise a relook into your design. If you are using Linear design, you would have close to 2.8W of dissipation in the power supply (assuming 250mA each for 7.5V and 5V). Thats too much heat.
    -Karthik
    Thanks Karthik will look at that also.
  • rwyost
    @rwyost-7Y1SOe • May 13, 2009
    godfather, for help with your design, please email me at #-Link-Snipped-# or visit our website at #-Link-Snipped-#.
