Can any one write this program without using "scanf"
sndgpr26
@sndgpr26-Yb3sXd โ€ข Oct 21, 2024
Write a program to take any number from the user and that can give the output of twice the number, without using "scanf"
  • Vishal Sharma
    @vishal-pysGmK • Aug 30, 2012
    Is this your doubt? or you already know it?
  • [Prototype]
    @prototype-G9Gn5k • Aug 30, 2012
    There are various alternatives. Command line arguments, fgets etc.
  • sndgpr26
    @sndgpr26-Yb3sXd • Aug 30, 2012
    Vishal0203Is this your doubt? or you already know it?
    no i dont know it
    actually some one had asked me to do this
    but i was failed
  • sndgpr26
    [Prototype]There are various alternatives. Command line arguments, fgets etc.
    sir
    can u please write the whole program
  • Vishal Sharma
    wrong info:
    you cannot do it by fgets()
  • Vishal Sharma
    no i dont know it
    but i was failed
    Note:: I'm not using scanf() but I'm using fscanf().. is that okay??
    #include "stdio.h"
    #include "conio.h"
    int main()
    int n,a;
    fscanf(stdin,"%d",&n);
    a=2*n;
    fprintf(stdout,"%d",a);
    getch();
    return 0;
  • Vishal Sharma
    i think its not correct ans. As scanf n fscanf() belong to same family
  • [Prototype]
    sndgpr26sir
    You got the info, give it a try yourselves. We're here to help you learn & what you're asking is not the correct way.
    Vishal0203wrong info:
    Well, you gonna do the same with command line arguments i.e. convert a string into a integer. Its surely a possible option.
  • Vishal Sharma
    Can you give a small example?
  • Vishal Sharma
    @vishal-pysGmK • Aug 31, 2012
    [Prototype]You got the info, give it a try yourselves. We're here to help you learn & what you're asking is not the correct way.
    what conversion you're talking about?? Will you lease elaborate and educate me about it??
    #include "stdio.h"
    #include "conio.h"
    int main()
    char n[1]; int a,b;
    fflush(stdin);
    fgets(n,sizeof(n),stdin);
    b = int(n);
    printf("%d",b);
    //a=2*n;
    //fprintf(stdout,"%d",a);
    getch();
    return 0;
    Is this you're talking about?? But doesn't give a desired output!! ๐Ÿ˜–
  • [Prototype]
    @prototype-G9Gn5k • Aug 31, 2012
    Same can be done with commandline.
    #include<stdio.h>
    #include<stdlib.h>
    int main()
    char n[20];
    int z;
    fgets(n, sizeof(n),stdin);
    z = atoi((char*)n);
    printf("String converted to integer is -> %d\n",z);
    printf("Adding 10 to the converted string -> %d\n",z+10);
    return 0;
  • Vishal Sharma
    z = atoi((char*)n);
    Can you tell me what this part actually does?? ? that was cool!!
  • [Prototype]
    Vishal0203Can you tell me what this part actually does?? ? that was cool!!
    That's actually the heart of the system atoi (ASCII to INTEGER) is the function which converts the string into integer. However, a major drawback attached to it is that it doesn't report error in case you pass something like "asdads" as input instead of numbers in form of string. You can use strtol() instead of atoi(), but I've just used it to keep the things simple.
    I've done a typecast to char* because atoi requires parameter as char* & not char.
  • Vishal Sharma
    I think we can make a check for number or string using conditional statements before passing it to atoi(), isn't it??
  • [Prototype]
    Vishal0203I think we can make a check for number or string using conditional statements before passing it to atoi(), isn't it??
    How so? Everything that will come as an input will be a string i.e. despite you're sending input as 123456, its will be treated as a string. To make the string distinguishable as an integer, we're using that function.
  • Vishal Sharma
    okay!! I surfed the net for strtol() ๐Ÿ˜€
    really cool!
    thanks to you!! ๐Ÿ˜€
  • sulochana anand
    @sulochana-anand-OrGmKr • Aug 31, 2012
    Vishal0203Note:: I'm not using scanf() but I'm using fscanf().. is that okay??
    #include "stdio.h"
    #include "conio.h"
    int main()
    int n,a;
    a=2*n;
    getch();
    return 0;
    y r u asking?if u used this code then definitely u must run it.wat was the result?
  • Vishal Sharma
    sulochana anandy r u asking?if u used this code then definitely u must run it.wat was the result?
    result was fine..
    I'm getting the desired result.
    but I'm using fscanf() which belongs to family of scanf(). That's the reason I asked
  • rahul69
    @rahul69-97fAOs • Aug 31, 2012
    Well here is my attempt :
    #include<stdio.h>
    #include<conio.h>
    main()
    int no,i;
    char s[40];
    gets(s);
    no=atoi(&s);
    printf("%d",no);
    getch();
    return 0;
    simply gets() can do...๐Ÿ˜Ž
  • sulochana anand
    Vishal0203result was fine..
    thats right.but u are using fscanf "stdin" but scanf need not to use stdin.The fscanf() function read from the named input stream. The scanf() function reads from the standard input stream .
  • Vishal Sharma
    @vishal-pysGmK • Sep 1, 2012
    gets()
    gets() is not a good suggestion as it overloads the buffer. Hence,
    avoid using gets as much as possible.
    for more info,
  • Vishal Sharma
    sulochana anandthats right.but u are using fscanf "stdin" but scanf need not to use stdin.The fscanf() function read from the named input stream. The scanf() function reads from the standard input stream .
    you're right but, the ques is about the function and as far as i know, scanf() fscanf() both belong to same family.
    anyways i got to learn a new thing ๐Ÿ˜€ atoi() i didn't know about it!
  • Priya Nadkarni
    @priya-e8RF2B • Sep 1, 2012
    How about cin(console input)? Its simple.
    Program-
    #include<iostream.h>
    int main()
    int num;
    cin>>num;
    cout<<num*2;
    return 0;
  • [Prototype]
    @prototype-G9Gn5k • Sep 1, 2012
    PriyaJHow about cin(console input)? Its simple.
    Program-
    int main()
    int num;
    cin>>num;
    cout<<num*2;
    return 0;
    Those are C++ functions. This discussion is about C.
  • Priya Nadkarni
    Oh k.
