Calibrate the notebook PC battery
Under normal usage, batteries should be calibrated a minimum of once every 3 months. Your battery can be calibrated by following these steps:
Step 1 - Disable the Windows Power Management
1. In Windows, right-click the Desktop and select Properties in the menu list.
2. Click the Screen Saver tab and then click the Power button.
3. Under Power schemes, select Always On in the drop down menu.
4. Under Settings for Always On power scheme, select Never in each of the drop down menus.
5. Click OK on the Power Options Properties window and then click OK on the Display Properties window.
Step 2 - Fully charge the battery
1.Connect the AC adapter to the notebook.
2.Charge the battery until the Windows battery meter is at 100%.
Step 3 - Fully discharge the battery
1. Remove the AC adapter.
2. Keep the notebook on until the battery has completely drained and the notebook automatically turns off.
3. Connect the AC adapter to the notebook.
4. Keep the AC adapter connected to the notebook until the battery has completely charged.
Step 4 - Enable the Windows Power Management
3. Under Power schemes, select Portable/Laptop in the drop down menu.
4. Click OK on the Power Options Properties window and then click OK on the Display Properties window.
