calculation of quantities for concrete
i just want to know how to calculate the quantities for concrete esp soil excavation and back fill and for steel too i mean the fastest possible way to do these?
    @ramani-VR4O43 Oct 18, 2016
    There are lots of on line calculators available for many of these calculations. Do a search for 'Concrete Calculator'.
  • prahu mac
    @prahu-NGsuBH Oct 21, 2016
    i mean sir i want to know the procedure for doing this?
  • Sumukh Madgaonkar
    @sumukh-T0cfqu Oct 21, 2016
    prahumaci mean sir i want to know the procedure for doing this?
    Calculation of quantity is as good as calculating the volume of the structure.
    Be it concrete, soil, reinforcement of structural steel!
  • Lokeshgaddam
    @lokeshgaddam-gMfCvz Nov 8, 2016
    For providing a raft foundation what activities are involved ?
  • Sumukh Madgaonkar
    @sumukh-T0cfqu Apr 10, 2023
    Excel Spreadsheets the best possible way.........
  • Julia Rowe
    @julia-rowe Aug 17, 2026
    Honestly, when I need quick numbers on site, I stick to basic multiplication.
    Excavation
    Length × width × depth. If the sides are sloped, take the average width. Add a little extra for working space and soil bulking, usually 5–10%.
    Backfill
    Excavation volume minus the volume of concrete, footing, pipe, or whatever else is sitting in the hole. Then multiply by a compaction factor. I normally use 1.2 to 1.3 depending on the soil.
    Concrete
    Length × width × thickness. For footings or columns, section area × length is faster. Add about 5% for waste.
    Steel
    The quick formula I use is D²/162 × length = kg, where D is bar diameter in mm. For common sizes: 8mm = 0.395 kg/m, 10mm = 0.617, 12mm = 0.888, 16mm = 1.58, 20mm = 2.47, 25mm = 3.85. Multiply by the number of bars and add 5% wastage.
    For repetitive takeoffs, I still double-check my numbers with a concrete calculation tool like CalculationHub. It doesn't replace the formulas, but it catches mistakes and saves time.
