@thebigk • Jan 17, 2010
Is this a C programming question?
@manish-r2Hoep • Jan 17, 2010
Neha KochharWhat is the value of the expression (3^6) + (a^a)?
a) 3 b) 5 c) 6 d) a+18 e) None
I am Unable to solve this Out?
Ans is 5 but how?
Explain the ProcessI think you want to solve this expression using c right?
ok
If you don't input the value of a then it will take garbage value..now in order to obtain output 5 in the expression it should be like this
(3^6)+(a^-a)
ie a's power is a negative value -
Neha Kochhar OP
@neha-kochhar-6BG7H3 • Jan 20, 2010
goyal420I think you want to solve this expression using c right?
ok
(3^6)+(a^-a)
ie a's power is a negative valuebut how the value 5 is obtained?
Please explain it .I did not get what you said -
@hussanal-faroke-U5nNM8 • Jan 25, 2010
is the 'a' defined, if no try it in another system? or u defined pls tell the value of a! u know in c 32767+1 is -32765
@rishita-FrQpNc • Jun 11, 2011
Nice Goyal. But, we want detail solution. How we get the answer. Can you give detail step by step process of solution.
Thanks for your solution.
Regards,
<link removed> -
@vik001ind-rOaCSy • Jun 11, 2011
It doesn't matter whether a is defined or not.
^ stands for XOR. Xoring same bit return 0, different values return 1. Eg, 1^0 == 1 , 1^1 == 0
Any int variable in C is 16 bit (16 bit compiler) or 32 bit (32 bit compiler). So, in any case whether it is defined or not, a will be a 16/32 bit pattern.
Considering 16 bit compiler
Bit pattern of 3 is 0000 0000 0000 0000 0011
XOR
Bit pattern of 6 is 0000 0000 0000 0000 0110
Result is --> 0000 0000 0000 0000 0101 ---> 5
a^a will always be equal to 0. Since we have bit pattern same in both cases.
Therefore (3^6) + (a^a) = 5.
