C++ project topic help
Arp
Arp
@arp-8yytsY โ€ข Oct 26, 2024
i've to do a project in c++ only. i want it to be somewhat related to electrical also.
means electrical side in come c++ programming..
please suggest me some topics that i can do...
    @harshad-ukH5ww • Feb 9, 2011
    Re: project topic help
    Then go with Embedded projects in that you have to work with both Electrical/Electronics (Hardware) and C++ or C programming (Software). you can find lot of projects in our Project Idea Section.
  • rajeshrao
    @rajeshrao-hgGq9f • Feb 14, 2011
    hello............
    first of all,you must know about difference between electrical and electroincs.these two are the same but slightly different from one another.because electrical components have more stable and it will give a perfect output.it's operates only high level voltage.it didn't operate in low-level voltage.
    but electronics components are stable depends upon voltage.it's operates only(0-30v).
    I am a project engineer.I COMPLETED my engineering degree last year.IN my point of view,
    you should prefer the EMBEDDED SYSTEM DOMAIN.BECAUSE it contains the software and hardware.software nothing but programming languages like c,c++,java. hardware nothing but microprocessor,and many electronics components.
    you prefer embedded system with c program.because c is a simple language when compared to others.you learn the c codings easily .c++ is the tough language.because it contains the object and class variables.embedded system domain is the bone of electronics,because it applies from low-level machine to high-level machine.it applies in terms of controller- operation.
    for-ex:automatic railway system.
    <a href="https://www.papercupmakingmachine.in/" target="_blank" rel="nofollow noopener noreferrer">www.papercupmakingmachine.in</a>
    home meter reading with gsm.
    pc controlled vehicle
  • sai krishna
    @sai-45XcSw • Feb 15, 2011
    i too vote for embedded based projects
  • sivi
    @sivi-tv4ZyF • Feb 15, 2011
    ya dats true......embedded project is da best option with embedded c...........
  • Arp
    Arp
    @arp-8yytsY • Feb 15, 2011
    guys, i dont have to make any hardware.
    only a software program based on c++ ( called as project).
    it is not like final year project or so.
    i just want to make a c++ program thats related to electrical engg.(like load flow studies)
    i just have thought of one topic yet and that too is making by alot many other classmates.
    so i want some topic help in such a way that software itself represent it is made by an electrical engineer..
    plz help in topics name CEans..
