C Programming Que. paper.
gaurav.bhorkar
gaurav.bhorkar
@gauravbhorkar-Pf9kZD Oct 22, 2024
I want to share some of the questions from my 3rd sem exam of C language.
Sharing ALL questions is not possible. (Most of them are easy)
Q1. Distinguish between (*m)[5] and *m[5]?
Q2. What is UNION? How it is different from STRUCTURE?
Q3. Distinguish between syntax and semantic error?
Q4. What do you mean by Input/Output stream?
Q5. Find the output of the program:
main()
int a=10, b=20, c=30, d;
d = a > b ? (a > c ? a : c) : b > c ? b : c;
printf ("%d",d);
Very easy questions!:smile:
  • yadavundertaker mohit
    @yadavundertaker-0p3HBs Nov 10, 2009
    for you they seems to be easy but for me like Schrödinger equation
  • Manish Goyal
    Manish Goyal
    @manish-r2Hoep Nov 10, 2009
    5😲utput of program will be 30
  • sarveshgupta
    sarveshgupta
    @sarveshgupta-txtmu5 Nov 10, 2009
    if you know Structure you also know Union
    they are collection of various data types but have a difference
    The memory of Structure is equal to the sum of the memory of all the data types
    But Union takes only the largest value only
    Say we have a char, int then memory for structure will be 3 while Union it will be 2
  • sarveshgupta
    sarveshgupta
    Syntax error is the error in the syntax that is use forget to follow the rules of writing code in C
    it means you forget a ';' or make a spelling mistake of 'printf to be pintf'
    Semantics are the logical errors they are generally not recognised by the compiler with exceptions of divide by zero
    Semantics means you have done a+b when you had to do a+c
  • gaurav.bhorkar
    gaurav.bhorkar
    @gauravbhorkar-Pf9kZD Nov 10, 2009
    goyal420
    Can you give justification for your answer?
  • gaurav.bhorkar
    gaurav.bhorkar
    @sarveshgupta
    All your answers are correct. Good.
  • Maelstrom
    Maelstrom
    @maelstrom-jwDZvD Nov 10, 2009
    gaurav.bhorkar
    (*m)[5] means "pointer to an array of 5 integers"
    *m[5] means "array of integer pointers"
    As for the Input/Output stream question, I'm not sure, but I think that they are interfaces provided to the programmer to ensure that he does not have to worry about the actual implementation of input/output (i.e. writing individual bytes to printer or monitor etc.).
  • sarveshgupta
    sarveshgupta
    @sarveshgupta-txtmu5 Nov 11, 2009
    Thanks Gaurav
    And as far as input/output stream are concerned
    Stream is an array of bytes
    all the input output of the values is considered as a stream of bytes by the compiler
    an int variable has 2 bytes , a char has 1 byte
    When the input and output is performed it is considered as bytes
  • Manish Goyal
    Manish Goyal
    @manish-r2Hoep Nov 11, 2009
    main()
    printf ("%d",d);
    first of all it will check whether a>b ie not true so it check b>c which is again false
    so it will give value 30
    I hope my answer is not wrong
  • gaurav.bhorkar
    gaurav.bhorkar
    @gauravbhorkar-Pf9kZD Nov 11, 2009
    goyal420
    main()
    printf ("%d",d);
    You are absolutely correct. Good Job!
  • gaurav.bhorkar
    gaurav.bhorkar
    I don't know about Input/Output stream.
    Sarveshgupta may be correct.
  • Gurjeet Singh
    Gurjeet Singh
    @gurjeet-LUX7B1 Nov 11, 2009
    main()
    printf("%%%%%",7);
    what is the output:
    1:7
    2:error
    3:%%%
    4:%%%%%
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M Nov 11, 2009
    It gives syntax error 😀
    The bracket mustbe } not {
    PS.Start new thread for questions 😀
  • sarveshgupta
    sarveshgupta
    I think he has placed that bracket by mistake
    and printf has everything inside double quotes except the variables whose values are to be substituted with their type specifiers
    Hope i am correct
