c program to check no. is even or odd without using conditional operator !!
Gaurav Deshmukh
@gaurav-ToXXkA โ€ข Oct 26, 2024
#include<stdio.h>
#include<conio.h>
int main()
  int no;
  char ch[0]="Even";
  char ch[1]="odd";
  printf("Enter a no. \t");
  scanf("%d",&no);
  printf("\n The no. is %s",ch[no%2]);
return (0);
// in above c code using % operator and array we can find the no. is even or odd also we can perform it by using bitwise AND operato (&) and AND operator (&&).................
I gave u the hint can anybody is able to write 2nd program ...๐Ÿ˜‰๐Ÿ˜€//
o/p--> Enter a no. 7
The no. is odd
Enter a no. 4
The no. is Even
    @anoop-kumar-GDGRCn • Sep 19, 2013
    Good program but in wrong category.
    You should post computer and IT related stuffs at following section:
  • nareshkumar6539
    @nareshkumar6539-BKuVbx • Sep 19, 2013
    Gaurav v. Deshmukh
    #include<stdio.h>
    #include<conio.h>
    int main()
      int no;
      char ch[0]="Even";
      char ch[1]="odd";
      scanf("%d",&no);
    return (0);
    The no. is odd
    Enter a no. 4
    The no. is Even
    When we use logical and or bit wise first it will convert number into binary format then it will perform the operation.
    When we perform Logical and or Bitwise and operation with NUMBER&&1 it will give
    one means it is ODD number it will give 0 means EVEN number.
    (NUMBER&&1)?"ODD":"EVEN" or (NUMBER&1)?"ODD":"EVEN"
  • rahul69
    @rahul69-97fAOs • Sep 20, 2013
    nareshkumar6539When we use logical and or bit wise first it will convert number into binary format then it will perform the operation.
    Logical And will not work! because logical And can only check if the number is non zero, to check even odd, you will have to use bitwise And ie '&'
  • Vinut47
    @vinut47-6dkCRt • Jun 24, 2016
    7 easy ways to find whether a number id odd/even.
