upgrade OP
@upgrade-aXrqLd • Feb 27, 2008
c code
can anyone giv me c code for addition of two single variable polynomials. -
@mahul-ZxpiLA • Feb 27, 2008
please be a little more elaborate if u can, like how u represent and store ur polynomials, the arguments u would like to pass to ur function and such stuff. By what u have posted, there was very little that i could comprehend.
upgrade OP
@upgrade-aXrqLd • Feb 28, 2008
i want to accept any length two polynomials like say 6x^3+5x^2
and 4x^2+5x+7
now i hav to take powers and coefficients of x from user.i hav done that.
but now i need to add these polynomials. -
@friendster7-oVJr9h • Mar 1, 2008
mynode *polynomial_add(mynode *h1, mynode *h2, mynode *h3)
mynode *p1, *p2;
int x1, x2, y1, y2, cf1, cf2, cf;
p1 = h1->next;
while(p1!=h1)
x1 = p1->px;
y1 = p1->py;
cf1 = p1->cf;
// Search for this term in the second polynomial
p2 = h2->next;
while(p2 != h2)
x2 = p2->px;
y2 = p2->py;
cf2 = p2->cf;
if(x1 == x2 && y1 == y2)break;
p2 = p2->next;
if(p2 != h2)
// We found something in the second polynomial.
cf = cf1 + cf2;
p2->flag = 1;
if(cf!=0){h3=addNode(cf,x1,y1,h3);}
else
p1 = p1->next;
}//while
// Add the remaining elements of the second polynomail to the result
while(p2 != h2)
if(p2 -> flag ==0)
h3=addNode(p2->cf, p2->px, p2->py, h3);
p2=p2->next;
return(h3);
}this will help u i guess..this can add two polynomials
@ashutosh-shukla-ed4Ei4 • Nov 17, 2008
I just joined the site and would like to contribute in here
Code in PASCAL using linked list
{Program to perform polynomial addition using linked list}
PROGRAM polyaddll(input,output); TYPE nodeptr=^node; node=RECORD coef:integer; exp:integer; link:nodeptr; END; VAR one,two,res:nodeptr; k:integer; PROCEDURE print(n:nodeptr); VAR p:nodeptr; BEGIN p:=n; WHILE (p<>NIL) DO BEGIN write(p^.coef,' X^ ',p^.exp); IF (p^.link<>NIL) THEN write(' + '); p:=p^.link; END; writeln; END; PROCEDURE create(VAR n:nodeptr); VAR p,q:nodeptr; c:char; BEGIN c:='y'; WHILE (c<>'n') DO BEGIN new(p); write('Enter the coefficient of the term : '); readln(k); p^.coef:=k; write('Enter the exponent of the term : '); readln(k); p^.exp:=k; p^.link:=NIL; write('Do you want to add any more terms (Y/N) : '); readln(c); IF (n=NIL) THEN BEGIN n:=p; q:=p; END ELSE BEGIN q^.link:=p; q:=p; END; END; END; PROCEDURE sum(VAR a,b,c:nodeptr); VAR p,q,r,s:nodeptr; BEGIN p:=a; q:=b; WHILE ((p<>NIL) AND (q<>NIL)) DO BEGIN new(r); r^.link:=NIL; IF (p^.exp>q^.exp) THEN BEGIN r^.coef:=p^.coef; r^.exp:=p^.exp; p:=p^.link; END ELSE IF (q^.exp>p^.exp) THEN BEGIN r^.coef:=q^.coef; r^.exp:=q^.exp; q:=q^.link; END ELSE BEGIN r^.coef:=p^.coef+q^.coef; r^.exp:=p^.exp; p:=p^.link; q:=q^.link; END; IF (c=NIL) THEN BEGIN c:=r; s:=r; END ELSE BEGIN s^.link:=r; s:=r; END; END; WHILE (p<>NIL) DO BEGIN new(r); r^.coef:=p^.coef; r^.exp:=p^.exp; r^.link:=NIL; p:=p^.link; IF (c=NIL) THEN BEGIN c:=r; s:=r; END ELSE BEGIN s^.link:=r; s:=r; END; END; WHILE (q<>NIL) DO BEGIN new(r); r^.coef:=q^.coef; r^.exp:=q^.exp; r^.link:=NIL; q:=q^.link; IF (c=NIL) THEN BEGIN c:=r; s:=r; END ELSE BEGIN s^.link:=r; s:=r; END; END; END; BEGIN one:=NIL; two:=NIL; res:=NIL; writeln('Enter the first polynomial : '); create(one); writeln('Enter the second polynomial : '); create(two); writeln('The first polynomial is : '); print(one); writeln('The second polynomial is : '); print(two); sum(one,two,res); writeln('The reult of addition is : '); print(res); readln; END.We Rock!!!!!!!
@pradeep-agrawal-rhdX5z • Nov 26, 2008
Hi friendster7,
I did not tried running your code but here are some of my view:
1. Since you are initilizing p1 & p2 with next of h1 & h2 and then comparing for (p1 != h1) and (p2 != h2), the conditions will not meet.
2. Code for addNode is required.
Here is my sample code for the given problem statement.
#include "stdio.h" typedef struct node { int cof; int pow; struct node *next; } nodet; nodet* createnewnode(int cof, int pow) { nodet* newnode = (nodet*)malloc(sizeof(nodet)); newnode->cof = cof; newnode->pow = pow; newnode->next = NULL; return newnode; } void deletepoly(nodet* head) { nodet* temp = NULL; while(head != NULL) { temp = head; head = head->next; free(temp); } } void displaypoly(nodet* head) { if(head == NULL) { printf("Empty polynomial\n"); } else { do { if(head->cof > 0) { printf("+"); } if((head->cof == 1) && (head->pow == 0)) { printf("1"); } else { if(head->cof != 1) { printf("%d", head->cof); } if(head->pow != 0) { printf("x"); if(head->pow != 1) { printf("^%d", head->pow); } printf(" "); } } head = head->next; } while(head != NULL); printf("\n"); } } nodet* addpoly(nodet* poly1, nodet* poly2) { nodet* newnode = NULL; nodet* retnode = NULL; nodet* retnodelast = NULL; nodet* temp = NULL; nodet* temp1 = poly1; nodet* temp2 = poly2; int cof = 0; int pow = 0; while((temp1 != NULL) && (temp2 != NULL)) { if(temp1->pow > temp2->pow) { cof = temp1->cof; pow = temp1->pow; temp1 = temp1->next; } else if(temp1->pow == temp2->pow) { cof = temp1->cof + temp2->cof; pow = temp1->pow; temp1 = temp1->next; temp2 = temp2->next; } else { cof = temp2->cof; pow = temp2->pow; temp2 = temp2->next; } if(cof != 0) { newnode = createnewnode(cof, pow); if(retnode == NULL) { retnode = newnode; retnodelast = retnode; } else { retnodelast->next = newnode; retnodelast = retnodelast->next; } } } if(temp1 != NULL) { temp = temp1; } else { temp = temp2; } while(temp != NULL) { newnode = createnewnode(temp->cof, temp->pow); if(retnode == NULL) { retnode = newnode; retnodelast = retnode; } else { retnodelast->next = newnode; retnode = retnode->next; } temp = temp->next; } return retnode; } int main() { nodet *poly1 = NULL; nodet *poly2 = NULL; nodet *polysum = NULL; nodet* newnode = NULL; nodet* temp = NULL; int order_poly1 = 0; int order_poly2 = 0; int cof = 0; int i = 0; //read polynomial 1 scanf("%d", &order_poly1); if(order_poly1 < 0) { printf("Polynomial of invalid order\n"); return 0; } for(i = order_poly1; i >= 0; i--) { scanf("%d", &cof); if(cof != 0) { newnode = createnewnode(cof, i); if(poly1 == NULL) { poly1 = newnode; temp = poly1; } else { temp->next = newnode; temp = temp->next; } } } //read polynomial 2 scanf("%d", &order_poly2); if(order_poly2 < 0) { printf("Polynomial of invalid order\n"); deletepoly(poly1); return 0; } for(i = order_poly2; i >= 0; i--) { scanf("%d", &cof); if(cof != 0) { newnode = createnewnode(cof, i); if(poly2 == NULL) { poly2 = newnode; temp = poly2; } else { temp->next = newnode; temp = temp->next; } } } //display polynomial 1 printf("Polynomial 1:\n"); displaypoly(poly1); //display polynomial 2 printf("Polynomial 2:\n"); displaypoly(poly2); //add polynomials & display resultant polynomial polysum = addpoly(poly1, poly2); printf("Result Polynomial:\n"); displaypoly(polysum); //delete polynomials deletepoly(poly1); deletepoly(poly2); deletepoly(polysum); return 0; }Compile the file with above code and run as:
a.exe < input.txt > output.txt [on windows]
a.out < input.txt > output.txt [on linux]
Here,
a.exe or a.out are the executables generated after compilation
input.txt is the file containing input, e.g., if the polynomials are
P1: 4x^2 + x + 1
P2: 5x^3 -4x^2 - 1
Then input.txt will be
2
4
1
1
3
5
-4
4
1
1
2 represent order of polynomial (4x^2 + x + 1) and then each number represents coefficients3
5
-4
3 represent order of polynomial (5x^3 -4x^2 - 1) and then each number represents coefficientsoutput.txt is the output file containing result, for given example output.txt will contain
Polynomial 1:
+4x^2 +x +1
Polynomial 2:
+5x^3 -4x^2 -1
Result Polynomial:
+5x^3 +x-Pradeep
