  • Rocker
    @rocker-ZpZLKM • Nov 9, 2006
    ravibharadwajint g=300*300/300;
    cout<<"g="<<g;
    what would be the value of g? If you think the answer is you got is correct
    Justify your answer.
    I'm not a C coder, but g = 109.223 ๐Ÿ˜‰
    Right?
    Justification, 300*300 exceeds max. integer range which is -32768 to 32767
  • amitpshukla
    @amitpshukla-IeGk30 • Nov 9, 2006
    radio designing
    i want to design a low power radio circuit, please give some ideas.
  • sahana
    @sahana-S4nL10 • Nov 10, 2006
    the answer will be 81.
    300*300/300
    first 300*300 will be computed which is 90000.this is greater than 32767 which is the limit of data type int.hence 90000%32767 will be calculated which is 24466.now this will be divided with 300 (as the expression is 300*300/300). hence the answer is 81.
  • crook
    @crook-0PFkJv • Nov 10, 2006
    sahanathe answer will be 81.
    300*300/300
    Sahan's explanation is better. I think the answer is 81. ravibharadwaj please post the correct answer.
  • ravibharadwaj
    @ravibharadwaj-vc2mZ7 • Nov 12, 2006
    Good one sahana and crook. Keep up the good work.
    post in more puzzels
  • rick
    @rick-JybHX8 • Nov 12, 2006
    ravibharadwajGood one sahana and crook. Keep up the good work.
    Is that the right answer though? Please confirm. I think 81 is the right answer.
  • ravibharadwaj
    @ravibharadwaj-vc2mZ7 • Nov 18, 2006
    Yup 81 is the right answer. Plz do post some c or c++ puzzles
  • Munguti
    @munguti-MnxkmE • Sep 30, 2010
    Re: radio designing
    I think you should start a new thread with a heading RADIO DESIGNING. Is it an AM or FM reciever
  • naveeen reddy polimera
    @naveeen-reddy-9lD8Ov • Dec 26, 2015
    according to the BODMAS rule division '/' will execute and then * will execute
    300*300/300=300*(300/300)
  • simplycoder
    @simplycoder-NsBEdD • Jan 4, 2016
    It can be 300 aswel, did anyone verify it?
    If yes, please share the os and which compiler and also the bit version of the compiler.
