C# Assignment help
Black_Rose
@black-rose-OYtC6o โ€ข Oct 22, 2024
Agh, okies I'm trying to loop my if statement, which loop should I use?
if (Tnumber > 25)
Console.Write("Invalid input!\n\nPlease enter a table number between 1 and 25: ");
Tnumber = Int32.Parse(Console.ReadLine());
Basically what the objective is, that if the user keeps entering a value higher than 25 it should continue to show that message until such time that a value below 25 is entered.. also whilst I'm asking... Can you also tell me how do I add another clause so that anything but the numbers between 1 and 25 also returns the same error message.
Thanks =)
  • shalini_goel14
    @shalini-goel14-ASmC2J • May 4, 2009
    Hi Black_Rose,
    I guess you can better use do...while loop
    something like below:
    do{
    if (Tnumber > 25)
    else
    break;
    }while(Tnumber > 0)  // or condition that proves that user has input a number.
    Hope I understood your problem and have answered well. ๐Ÿ˜€
  • Black_Rose
    @black-rose-OYtC6o • May 4, 2009
    Shalini, that's absolutely perfect thank you. I attempted the do while loop, but messed it up somehow :S I've changed the following on your code:
    else
    Console.Clear ();
    break;
    Just so when I'm done it clears the screen and displays new information.
  • Black_Rose
    Okay this is another part I'm struggling to understand. I'm asking the user to code in p for pizza and d for drinks. If it's a p then a pizza menu will show up if d is typed in than a drinks menu. How do I assign the 'd' and 'p' to show their respective menus? I've done the following:
    Console.WriteLine("\n\n\t\t\tPlease enter which menu you would like to order from: \n\n\t\t\t\t1) Type 'p' for Pizza \n\n\t\t\t\t2) Type 'd' for Drinks\n");
    Console.ReadLine();
  • shalini_goel14
    @shalini-goel14-ASmC2J • May 5, 2009
    Hi Black_Rose,
    I am not sure whether you tried something like following:
    // assigns whatever user enters to a variable menuSelectOption
    String menuSelectOption= Console.ReadLine();
    Hope I understood your problem correctly. ๐Ÿ˜€
  • Black_Rose
    @black-rose-OYtC6o • May 5, 2009
    Shalini, thanks alot for your help, don't worry I found out I need to use switch statements =) <3
