  • Building (Mid rise)
    undo
    Member
    Updated: Oct 26, 2024
    Views: 1.1K
    its 15-25 storey building. using c40 concrete. 1st floor column is 1000mmx1000mm = roughly 5400kN (550 tonne). whats your comment 😕
  • Aashish Joshi
    MemberOct 15, 2010
    Can you make the point of this post clear? Are you looking for someone to validate your design?
  • vidyanatarajan
    MemberOct 19, 2010
    If the dia of steel is about 20mm ,then
    area of steel(As)=314.159mm^2
    area of concrete(Ac)= 999685.8mm^2
    we know that stress =(load/eq.area)
    hence stress =5.37N/(mm^2)
    if you expect some thing else let your points be clear
