Braking System Design help wanted...
vegbruiser
@vegbruiser-qwzXGk โ€ข Oct 25, 2024
Hi folks,
we are currently trying to design a braking system, but are a bit stuck for ideas. It has to be capable of the following (see image) and it can't use pneumatic, electric or hydraulic: -
[โ€‹IMG]
The 10kg load has to be raised up 150mm, held for an indetermined time and then lowered down again.
Our best idea so far is essentially a conical brake: -
[โ€‹IMG]
Does anyone else have any other/better suggestions?
(Also, the size of the shafts involved is roughly 10mm dia.)
  • zorif
    @zorif-NVUQGT • Jun 8, 2009
    Re: Design help wanted...
    how abt counter weight.
    or a simple gear box will do the job.go for some good reduction ration.the weight to be held will be taken care by the gear box output shaft.
    or u will get ready electrical brake in market.simply use them.(might cost between 800-1000 bucks)
  • zorif
    BTW,iam quite impressed with the design.
    and what are u suing for the sliding mechanism.guide ways??
    and what abt the driving mechanism.ball screw or just lead screw.
  • getnoticed24
    @getnoticed24-49rgVf • Jun 10, 2009
    hi...
    u can end this design by switching to a chain-pulley transmission system.
    another suggestion is to use a well-greased screw jack arrangement....
    u are gonna use a conical brake, right....
    in that case ,if u leave the handle ,the load goes back to the original position....
    keep posting info about this model
  • Tkelly
    @tkelly-CKF896 • Jun 11, 2009
    Arrangement in model diagram looks ok but confirm the following.
    1) Middle rod on which load slides will have square threads and slider fitted with nut.
    2) Incease the dia. of handle sprocket to reduce the effort.
    In short it becomes screw jack.
    Tom
    <a href="https://www.indovance.com" target="_blank" rel="nofollow noopener noreferrer">CAD Outsourcing Services India | Indovance Inc</a>
  • jhbalaji
    @jhbalaji-AH60JJ • Jul 25, 2009
    I have an another idea instead of using handle why can't you use and electro magnet in both sides to lift and pull down loads...
  • Tkelly
    @tkelly-CKF896 • Aug 7, 2009
    I do not understand how electro magnet will work here. Please explain.
    Tom
  • jhbalaji
    @jhbalaji-AH60JJ • Aug 8, 2009
    Just when we supply power those magnets try to attract Iron Particles mates..
    So heavy magnetization [to produce heavy magnetic field] may help in lifting up mate...
  • gohm
    @gohm-F3UUpP • Aug 8, 2009
    In the notes it states they cannot use electricity.
  • jhbalaji
    Sorry mate ..
    I didn't saw that...
