@anoop-kumar-GDGRCn • Aug 3, 2015
Tell us more!! What you like to do but not able to do because of xyz reason.
What you like to do which make you feel good?
What you like to do in vacation or what you want to do (Forget about money thing for a instance) -
@rajeshraju-pwAMtk • Aug 4, 2015
Because of failures i m not able to thing anything friend. fully in confusion..
@thebigk • Aug 4, 2015
rajeshrajuBecause of failures i m not able to thing anything friend. fully in confusion..
Guess what? I'm continuously failing at one simple task for the last ~4 years. I'll talk about it some time (once I achieve my goal). But I'm determined to not quit.
If you share your confusion or failure with us - you might feel better. If there's anything we can help with, we'd be happy to. Otherwise, this discussion will be pointless. -
sir actually i m a good learner but first time when i failed in my engineering that time i lost my elgibility so that time i thought to work for part time for my pocket money but after that i totally involved in work i left studing totally i disturbed. after that again i started writting exams but i m failing in all exams but now also i m doing part time work sir actually for busyness purpose i lost 1000000 my dad money also so now i m trying to recover sir totally my mind is empty i m not getting what to do also this year also i fail in 2 subjects..
@vignesh-ITVbwh • Aug 4, 2015
Hello Friend .. I am not having any such experience . But to my point of view, you are so much confused.... You doesn't have a proper or constant mind set. you said you are a good learner. First of all I appreciate you. Failure may stroms in everyones life. Don't get tensed or fear of failures. Try your level best to come across of it.
You decided to go for work.. But therealso you are not in a steady state. Your mind get oscillates. This is the main obstacles in your life.
First get relax your mind. Think deeply and steadily. Find a right way either you are interested in studies or rather in business . Put your effort in a steady and constant path.. Success may automatically comes and knocks your door... -
@anoop-kumar-GDGRCn • Aug 4, 2015
Loosing parents money and not able to perform in study. Definitely puts huge pressure. But on other side you have lots of learning.
You have to leave past behind.
Analyze your weakness and strong areas and start your steps.
VIGNESH ANANTHA KRISHNANPut your effort in a steady and constant path..
I second that. This is best way get on right track.
Thank u very much i wil try my level best ....
@manish-r2Hoep • Aug 7, 2015
Dude failure is part of life, and you should not feel bad about it, I was rejected by several companies during my engineering days though having good percentage and was not placed in college, but after consistent efforts and lil bit interest in programming language I am ok and in good position today
I understand you have lot of pressure on your mind, Right now it is important for you to keep company with people having positive thinking that will motivate you
Also just be lil active on CE you will learn a lot from like minded people here -
@rajeshraju-pwAMtk • Aug 9, 2015
ya sure thank u very much..
