  • boost converter
    lapputappu
    Member
    Updated: Oct 25, 2024
    Views: 1.2K
    hiii friends i m making a practical model of boost converter ...
    V r trying to boost 24 v d.c to 300 v d.c ......
    so plz if any body can help me in this to make my project tell me first wot r the basic things i m gonna need ?
    Actually i have worked on the software model of this project which was quite appreciable...
    u can go through the software model ..
    now if u help me i'll be quite grateful to u.....
    wot else u wanna kno in the technical terms jst tell me ...
  • Codex Guides
    MemberFeb 7, 2010
    I would think the first thing you're going to need is a controller IC. I'd start with Linear Technology to see if they have anything suitable. The chip you use will determine all the other components that you'll need.
    - CG
  • lapputappu
    MemberFeb 7, 2010
    i went through the website. it was undeterminable for me to find from this website
    plz give me detail .or tell me wot u wanna tell me
  • Codex Guides
    MemberFeb 7, 2010
    A quick search shows the LT3757 will boost up to 350V.
    #-Link-Snipped-# for the data sheet. You'll have to read through it to see if it's OK for your application or not.
    - CG
  • lapputappu
    MemberMar 17, 2010
    v r trying to run a three phase 1 hp motor of 220v ,6 amp ,50 hz. so as per ur calculations it needs 46.75amp current .how it can be attained ?
    smone has also told me y dnt u r doin it with 1kw inverter .all u wud hav to do is change the transformer winding for three phase output.but wot d prblm with it is v r getting a quasi sine wave output wch is producing humming sound.so now wot can u help ?
    ur ideas are most welcomed.
