there is a blue window error message in my computer.windows is not starting.now i am working on linux. what should i do?0
Member • Jan 11, 2010
The "blue screen of death" is displayed when a device driver malfunctions.
You should remove your recently connected hardware. Or try to install updated drivers for your hardware.Are you sure? This action cannot be undone. -
well thanks gaurav.....but i have partitioned my hard disk into linux and windows.the linux is working correctly.but not windows.😕Are you sure? This action cannot be undone. -
Looks like some of the windows boot files got corrupted and windows is not able to boot up and showing the blue screen of death. If this is the case you need to repair the windows.
Cautionary Note: You will loose you windows drive (c:\) data if you will repair windows.
-CBAre you sure? This action cannot be undone. -
You should keep working on linux 😀Are you sure? This action cannot be undone. -
Member • Jan 12, 2010
The blue screen is shown when your window is going to be crashed or there is some problem in boot file.....the only thing u can do now is to reinstall the windows......;-)Are you sure? This action cannot be undone. -
Not necessarily, you dont have to reinstall windows. You can try making sense out of the text on that blue screen. Generally this happens due to an IRQ error, or some such problem.
Have you recently added a new hardware device, driver, etc? If so, revert back to the previous stable state (System Restore).Are you sure? This action cannot be undone.
