  • Blue Screen Appears and PC Restarts Automatically
    Chandan Nasta
    Chandan Nasta
    @chandan-nasta-dOxz7f
    Updated: Oct 26, 2024
    Views: 1.4K
    I dont know what to do. Experts please help me out:
    Problem signature:
    Problem Event Name: BlueScreen
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 1033
    Additional information about the problem:
    BCCode: 19
    BCP1: 00000020
    BCP2: 8A124019
    BCP3: 8A124D91
    BCP4: 09AF9DC8
    OS Version: 6_1_7601
    Service Pack: 1_0
    Product: 256_1
    Files that help describe the problem:
    C:\Windows\Minidump\010416-21808-01.dmp
    C:\Users\Chandan\AppData\Local\Temp\WER-78343-0.sysdata.xml
    Read our privacy statement online:
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
    Problem signature:
    Locale ID: 1033
    BCCode: 1000007e
    BCP1: C0000005
    BCP2: 83052555
    BCP3: 8EFB7510
    BCP4: 8EFB70F0
    Service Pack: 1_0
    Product: 256_1
    C:\Windows\Minidump\110115-29094-01.dmp
    C:\Users\Chandan\AppData\Local\Temp\WER-142943-0.sysdata.xml
    Problem signature:
    Locale ID: 1033
    BCCode: 1000008e
    BCP1: C0000005
    BCP2: 83078555
    BCP3: BE6EB994
    BCP4: 00000000
    Service Pack: 1_0
    Product: 256_1
    C:\Windows\Minidump\110415-17955-01.dmp
    C:\Users\Chandan\AppData\Local\Temp\WER-60715-0.sysdata.xml
    Problem signature:
    Locale ID: 1033
    BCCode: d1
    BCP1: 0000002A
    BCP2: 00000002
    BCP3: 00000000
    BCP4: 8D391293
    Service Pack: 1_0
    Product: 256_1
    C:\Windows\Minidump\110915-22370-01.dmp
    C:\Users\Chandan\AppData\Local\Temp\WER-65972-0.sysdata.xml
    Problem signature:
    Locale ID: 1033
    BCCode: c5
    BCP1: 01000004
    BCP2: 00000002
    BCP3: 00000001
    BCP4: 8315F4C1
    Service Pack: 1_0
    Product: 256_1
    C:\Windows\Minidump\112315-18439-01.dmp
    C:\Users\Chandan\AppData\Local\Temp\WER-73211-0.sysdata.xml
    Problem signature:
    Locale ID: 1033
    BCCode: e4
    BCP1: 00000001
    BCP2: FFFE001A
    BCP3: 00000400
    BCP4: 00000000
    Service Pack: 1_0
    Product: 256_1
    C:\Windows\Minidump\122415-17752-01.dmp
    C:\Users\Chandan\AppData\Local\Temp\WER-62150-0.sysdata.xml
  • rahul69
    MemberJan 10, 2016
    #-Link-Snipped-# , it would've helped if some preview was given (as how it happened etc.)
    For the time being, I would say, run chkdsk /f for the OS drive (eg C😀 and see if it fixes the issue.
  • Chandan Nasta
    MemberJan 10, 2016
    Rahul, the PC starts on its own after blue screen and it works in a normal as it is so I have juz pasted the error report it happens once in a day or two so in a week 3-4 times only. I really don't know what's the issue
    AdministratorJan 10, 2016
    Chandan Nasta
    Did the error happen after you installed something or did any changes to the hardware? We need to know the backdrop of this event - so that we can suggest you a possible fix.
    Did you, by any chance, upgrade memory OR updated driver?
  • Chandan Nasta
    MemberJan 10, 2016
    No Nothing new has been installed.
  • Kryptik
    MemberJan 10, 2016
    Chandan Nasta
    There is a possibility that this happened due to a few basic issues .
    Check the following :
    1. Open the CPU , remove the RAM from its socket. clean the socket. Clean around the processor fan similarly. Fix one of the RAM cards ( I'm assuming you have both slots filled ) and restart the system.
    Check with the other RAM card and then again with both.
    1.1 if it works with one but not the other , replace the other card. Its probably a faulty RAM card.
    1.2 If it works with either but not both , then do get your RAM sockets checked theremight be a circuit break , they might request a motherboard change.
    2. Once you've checked it , If you have a spare SMPS do replace and check it. ( remember to use a similar model )
    3. Do approach a service centre to identify if It is a motherboard fault.
    I doubt it is an OS issue, but I'd advice you to back up data and try a reformat before you go for an expensive solution.
  • Chandan Nasta
    MemberJan 10, 2016
    Do you know any good technician in Mumbai who is well versed with this?
  • rahul69
    MemberJan 13, 2016
    Chandan Nasta
    Next time when it comes please check and revert with following information:
    There will be a warning like:"A problem has been...damage to your computer"
    After this will be a message like:
    BAD_POOL_HEADER (or something else written, this is the reason why it is happening, pls share the same)
    At the end there will be technical information like:
    ***STOP: 0x000000FD (0x00000...., 0x0000.....,0x0000....,0x0000....)
    Please note down the values which come for your PC during blue screen, in the above format and share, it could be 0x000000EA or some other values for your PC, based on this information, the reason of BSOD can be verified.
  • Chandan Nasta
    MemberJan 14, 2016
    rahul69
    Okay I will. Thanks 4 the update
