Block USB Drive
as_nawin
as_nawin
@as-nawin-adRdf9 Oct 26, 2024
To this what can be done is that the USB can be blocked and then stopping the use of USB drives. Here is a simple registry hack to do so, try it with care.
1. Go to Start –> Run, type Regedit.
2. Go to HKEY_LOCAL_MACHINE\System\CurrentControlset\Servic es\USBStor
3. In the right pane, look for value Start and have value as 0000000(3)
4. Double click on that and change that value to 4.
You might be required to restart the PC, and then you are done with it, USB is now blocked.
In case if you want to get the USB unblocked, just change the value again to 3
  • Manish Goyal
    Manish Goyal
    @manish-r2Hoep Oct 16, 2009
    nice tip
    actually i need it
  • safwan
    safwan
    @safwan-NH7W5Y Oct 17, 2009
    Hay buddy I think no modes present today Please put your posts on appropriate place.
  • Sahithi Pallavi
    Sahithi Pallavi
    @sahithi-oJZaYj Oct 18, 2009
    Nice trick...I think Computer tips & tricks thread is the right place to post this.
