  • bicycle movement!
    anu_mech
    anu_mech
    @anu-mech-XkawyC
    Updated: Oct 26, 2024
    Views: 1.2K
    if a bicycle moves forward on forward pedalling....then why it does not go backward on backward pedaling....is the backward movement blocked or what?...if yes then what is the mechanism?
  • antenna
    MemberOct 10, 2009
    There is a pawl - ratchet mechanism inside.
  • Plasma
    MemberOct 11, 2009
    genuinely a bicycle is pedalled forward. If it was designed to go backward while 'backward pedalling' we would have a big loss because slight backward pedalling would incur a huge decelleration. Well, we can design gear that intakes both forward and backward input for the output in the same direction.
    anu_mech
  • 4d1
    MemberOct 12, 2009
    [​IMG]
    its ratchet-pawl mechanism
  • gohm
    MemberOct 12, 2009
    Yep, as a kid I remember the bikes not having that feature (except ten speeds) and pedaling backwards were your brakes. You sure could do som serious power slides with those as compared to the lever brakes.
  • anu_mech
    MemberOct 12, 2009
    thanx all!
  • 4d1
    MemberOct 13, 2009
    gohm
    are those still available...and how much effective are they?
  • gohm
    MemberOct 14, 2009
    I'm sure they still are. The braking that way was much more effective then the handlebar lever/wheel pad style. At least at that time anyways. My sisters had 10 speeds and I could easily out brake their bikes on my dirt bike even though you only had a rear brake. Power sliding was always a lot of fun. If I then jumped onto a 10 speed I would always initally try to brake by back pedaling before I realized I was just free spinning. laugh
