belt drives
zaveri
@zaveri-5TD6Sk โ€ข Oct 22, 2024
hey guys tell me how to determine the following:
consider two v-pulleys connected by a v belt. the speed at which the driving pulley rotates is known . how do we determine the torque on the driver pulley as well as the speed of the driven pulley and the torque transmitted to the driven pulley by the driver.
we know : the diameters of both the pulleys
the angle of slip of the belt
    @ramani-VR4O43 • Mar 10, 2012
    zaverihey guys tell me how to determine the following:
    consider two v-pulleys connected by a v belt. the speed at which the driving pulley rotates is known . how do we determine the torque on the driver pulley as well as the speed of the driven pulley and the torque transmitted to the driven pulley by the driver. we know : the diameters of both the pulleys
    This may help:
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • Mar 10, 2012
    bioramaniserver trouble. Multiple posts.
    Yeah, even I faced one!!! ๐Ÿ˜” #-Link-Snipped-#, please look into this...
    @thebigk • Mar 10, 2012
    Problem fixed. We're performing server operations that result into lag. Sorry for the inconvenience.
    The_Big_KProblem fixed. We're performing server operations that result into lag. Sorry for the inconvenience.
    Is it just me? The quoted post says it is #2, while there are more than 3 posts above!!!
    Praveen-KumarIs it just me? The quoted post says it is #2, while there are more than 3 posts above!!!
    I deleted the posts, that's why.
    The_Big_KI deleted the posts, that's why.
    Hey, wait... This is an awesome thread... Goes in the number of:
    #1
    #1
    #1
    #2
    #3
    #4
    ๐Ÿ˜€
    #-Link-Snipped-# : You are spamming this thread. Stick to the topic, please.
  • CE Designer
    @ce-designer-BWq0yl • Mar 12, 2012
    To determine the torque on the driver pulley you must first find the tensions T1 and T2 on the belt.
    Torque = (T1-T2)*(Radius of the driver pulley)
    To determine Speed of the driven:
    Use the ratio: Speed of Driver * Radius of Driver = Speed of Driven * Radius of Driven
    i.e. v1r1 = v2r2
  • zaveri
    @zaveri-5TD6Sk • Mar 12, 2012
    CE DesignerTo determine the torque on the driver pulley you must first find the tensions T1 and T2 on the belt.
    i.e. v1r1 = v2r2
    thanx a lot dude, now can u tell me how to determine the belt tensions
  • CE Designer
    e^(u)(theta) = (T1-Tc)/(T2-Tc)
    where T1 is the maximum tension which the belt is specified for
    u = coefficient of friction
    Tc = mv^2
    m = mass of the belt
    v =RPM*(2pie/60)*radius of driver
    You can now find T2 knowing T1 and Tc.
    be sure to use standard units and theta is in radians
  • zaveri
    CE DesignerYou can now find T2 knowing T1 and Tc.
    thanx again. but the problem is i do not know T1 either . now what to do
  • CE Designer
    I would suggest you search the manufacturer's specifications. Call your supplier or visit their website.
    I am not sure but check on the belt itself to see if there is any indication there.
