Beam Discussion
Beams is also important in building construction. I don't have much more idea about beams so by this thread I can improve my knowledge and also other CEans.
Let's start the ball rolling!!!
Member • Mar 16, 2011
Member • Mar 22, 2011
Member • Dec 20, 2011
Beams are horizontal structural members which are capable of taking Bending. Now bending stresses comes from imposed loads, self weight and reactions. Where ever these forces are there and there is an structural element resisting it we call it a "Beam" irrespective of whether it is of Building structure or Bridge Structure. Type of loading are definitely different in both the cases, so, their cross sections are also different. Hope this helps!!!maria florWhat is the difference of beams used in buildings and bridges???
Member • Dec 22, 2011
rollers are used at the ends of the beams, mostly in bridges because it allows the structure to expand and contract with temperature changes. if the ends are locked at the ends, then during expansion, there can be formation of cracks. the rollers are designed in such a way that there is only limited amount of lateral movement due to expansion. in any structure as such, there will be lateral forces acting. if they are high, it causes damage. so there will be other types of support along with rollers.maria florAnother question what's the purpose of putting a roller at one end of the beam???
Member • Feb 18, 2012
to give a chance for the beam to slide on it when expanded or contracted due to temparature😀maria florAnother question what's the purpose of putting a roller at one end of the beam???
fixed beams ,cantileaver beams,over hanging beams,contineos beamsmaria florWhat is the difference of beams used in buildings and bridges???
Member • Feb 19, 2012
you can use it for RCD design.. shear force in beams is used for designing the stirrups for beamsVengalam Raghumay i know what is the use of finding the shear force in beams...😐
Member • Feb 20, 2012
Member • May 13, 2012
Shear force can cause specific diagonal cracks near the beam supports. That's why we put stirrups 😀 For the short beams the shear force is critical.maria florshear force in beams is used for designing the stirrups for beams
Member • Jun 6, 2012
