  • Battery that charges on air
    sowmiya vd
    sowmiya vd
    @sowmiya-vd-gsAvTI
    Updated: Oct 15, 2012
    Views: 1.1K
    LITHIUM AIR BATTERIES
    Arthur Dobley, metal air battery scientist, explains “Li-air batteries breathe oxygen from the air, and allow it to react with the Li metal anode. These are constructed in layers, like a sandwich, of the lithium metal anode, separator with electrolyte and then the air cathode . the air cathode is the critical part, and that is where oxygen enters to cells and reacts.”
    PROF. Peter J. Hall explains:
    “The capacity of Li-air batteries is 10-20 times greater than traditional Li-ion batteries. These will also be considerably cheaper as they contain very little heavy metal content”.
    These are environment friendly.
    Lithium content in them can be recycled.
    Li-air battery is very lighter than Li-ion battery.
  • Jeffrey Arulraj
    MemberOct 15, 2012
    Hey can you post pics and also the cell eqn of the battery
  • sowmiya vd
    MemberOct 15, 2012
    i dont know the equation!!!
    anode,cathode and electrolyte is
    ANODE:
    Anode is composed of a lithium metal foil.
    Its is pressed into a nickel mesh current collector.
    The area of anode is slightly larger than the cathode by 10 cm-sq.
    SEPARATOR & ELECTROLYTE:
    Setela, an organic polymer, is used as the separator and the liquid electrolyte used is ethyl carbonate, diethyl carbonate and dimethyl carbonate.
    CATHODE:
    cathode composite carbon, a metal catalyst and a binder deposited on metal collector.
    The binder is Teflon combined with latex and the metal current collector is nickel.
    On both sides of metal current collector, two layers of carbon, binder and catalyst mixtures are deposited.
    A thin Teflon film between the air cathode and the atmosphere repels atmospheric water but allows oxygen diffusion
    AdministratorOct 15, 2012
    A few months back, an article appeared in the Scientific American that discusses the Lithium-Air batteries.
    Check -
    It says at the end that it might take a decade for this innovation to materialize, but I think some of the crazy engineers here can shorten that time-gap. 👍 Keep pouring your ideas here.
  • Jeffrey Arulraj
    MemberOct 15, 2012
    The problem I find is very simple best way of coupling the environmental free oxygen to the cathode of the cell the proper elemental procedure is not so great till date
  • lal
    MemberOct 16, 2012
    Does that mean its kind of renewable!
  • Jeffrey Arulraj
    MemberOct 16, 2012
    Not exactly renewable it is going to breathe in oxygen and ehale some other liquid mostly water i guess but if it is rechargeable then it is worth trying out otherwise given the efficiency it is a poor design
