Battery life span
da_joker
@da-joker-fQp3VY Oct 26, 2024
Am currently working on how to enhance the battery life span especially the one to be used in d design of an electric car.. Does anyone have ideal on what can help
    @thebigk Jun 27, 2011
    Could you post battery specs you've decided to use for the car?
  • rubensg
    @rubensg-xq7xaE Jun 27, 2011
    It would be a better help if you post the specifications of the battery and the machine you are going to run it into. You cannot generally make it last longer because there is constant consumption but what you can do is minimize the use on certain aspects that could be used with. Like use auto shut off for components that are not used and just restart them whenever they are needed. you need to compute however if the restart would cost more than just setting it to idle.
    The first thing that popped up in my mind was - is this going to be a Electric Vehicle or just a model, scaled-down car. To the best of my knowledge entirely different techniques are employed in bigger cars like Tesla Roadseter.
  • da_joker
    @da-joker-fQp3VY Jun 27, 2011
    For now it is going to be model for an electric vechicle. The battery spec is d lithium-ion battery with a power capacity of 12.7*kW·h/100*km (0.21*kW·h/mi) and the well-to-wheels efficiency..the electricity dat is generated from natural gas is 24.4*kW·h/100*km (0.39*kW·h/mi)..so making d battery have power output all most to d power output of d natural gas..is d main problem..any ideal of wat to do..
