AUTOMATIC SPEED CONTROL SYSTEM
Velshankar MJ
@velshankar-sD1Glu โ€ข Oct 25, 2024
For avoiding rash driving of the drivers we have to provide safety systems with in the vehicles mainly for 4-wheelers. We can make this by using sensors and electronic circuits, which costs more. Rather than providing such high cost equipment we can achieve the same thing by mechanical means.
In this system there is one power source (battery) as input, one controlling element (toroidal coil with controlling rod arrangement), and small modifications in the already existing conventional design of S.I &C.I engines and connections with brake, which simply acts as a switch
It is the system, which mainly uses the electrical power source and electronic circuits for controlling of the vehicle speed. It is mainly have the following components. It has the connections with brake, carburetor incase of S.I. engine and fuel injection pump in case of C.I. engine.
upload_2013-10-8_22-53-17
  • Anil Jain
    @CrazyBoy Oct 8, 2013
    I believe this is already in existence.
    Few months back I read an article that in US, Car companies has given the features where parents can control the vehicle speeds of their wards; that too using mobiles.
    All they needed to do is using mobile, connect to the control system of car and set the highest speed of the car, and regardless of how much throttle ward is pressing, car will not go beyond a speed limit.
    I am not too technical in mechanical systems so may not be able to comment on the circuit diagram at this moment. However, I will search through the article and may update this thread.
    -CB
  • zaveri
    @zaveri-5TD6Sk Oct 8, 2013
    In that case why don't we simply not use the mechanical governors ?
    @sarathkumar-FEGRPw Oct 9, 2013
    Velshankar MFor avoiding rash driving of the drivers we have to provide safety systems with in the vehicles mainly for 4-wheelers. We can make this by using sensors and electronic circuits, which costs more. Rather than providing such high cost equipment we can achieve the same thing by mechanical means.
    What is the advantage of having a toroidal coil operated speed control over old governing system? I dont think its a good idea to slow down a vehicle by braking it beacuse more power loss is experienced due to braking. So why can't we have a system(ECU) which automatically cut down the fuel supply when the vehicle reaches certain speed limit?(Notify if this system already exists)
